Installed: Earls brake lines
Old Nov 2, 2002 | 04:18 PM
Benny's Avatar
Just installed Earls brake lines 28A190 and WOW what a difference, firmer brake feel and probable shorter stopping distance. highly recommended over stock.
Old Nov 2, 2002 | 08:47 PM
BORLAZ06's Avatar
Nice to hear the results. I have their lines as well though they've been sitting in my garage for over a year...lol. I need to install them one of these days.
Old Nov 2, 2002 | 09:19 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
how much are the lines? are they the braided replacement hoses? thanks.
Old Nov 2, 2002 | 09:23 PM
BORLAZ06's Avatar
They were about 70 bux at the time and they are steel braided replacement hoses.
Old Nov 3, 2002 | 12:29 AM
Benny's Avatar
Costs me $95 now at Summit, 5 piece set, 2 for front and 3 for the rear including the center piece. East install.
Old Nov 3, 2002 | 01:54 PM
MdFormula350's Avatar
i hear great things about them..
i most likely have the stock hoses on my car and need to replace them when the next brake job comes along..
so i will buy them for my car....
Old Nov 4, 2002 | 11:25 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I thought only one brake line was required for the rear
Old Nov 4, 2002 | 11:57 AM
pianiy's Avatar
Two wheels=two brakes=one hose/side
There's one hardline that runs to the rear, then its joined with a flexible rubber hose that goes to a brass distribution block mounted on the rear differential which splits to two hardlines going to either wheel, from there they join with the flexible hoses to the calipers.
Old Nov 4, 2002 | 12:22 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
ok I see, but for rear drums it's just one flex line right. hard lines run to each wheel cylinder
Old Nov 4, 2002 | 06:45 PM
LilJayV10's Avatar
Engine: 406 Roller
thats the way it is on my car, and about every other rear drum vehicle i have ever worked on.
Old Nov 4, 2002 | 10:55 PM
Benny's Avatar
For the 4 wheel disc cars they have a hose for each wheel plus the middle hose with the fluid connection for the hard lines.
Old Nov 5, 2002 | 02:43 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
You wouldn't happen to have a part # would you? So I can bookmark it. I've only seen the 3 piece ones.
Old Nov 5, 2002 | 03:02 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Please note that these WILL NOT, in themselves, give you a shorter stopping distance. They flex less (less stretch) so you will probably feel a firmer pedal...but that's going to take a really well trained foot.
Clem
Old Nov 5, 2002 | 04:40 PM
Benny's Avatar
The part number is ERL-28A190 Hyperfirm Chevy Camaro brake hose kit for 4 wheel disc brakes. These things are far superior to the crapy rubber ones but they are pricey.
Old Nov 5, 2002 | 04:46 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
These brake lines are very very good. I had them in my car. Sadly only like 2 days of having them a lady smashed into me. And one of htem broke!!! AHHHHHHHHHHHH!!! (her car hit my rim area bending my spindle, control arm, and brake line.)
Old Nov 6, 2002 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Got'em, like'em, buy'em.
JamesC
Old Nov 6, 2002 | 12:40 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
on the 9-bolt that i installed on my car, only one of the rear calipers had a rubber line to it. the other caliper was hard lined.
wierd huh?
Old Nov 6, 2002 | 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If I'm not mistaken, my Dana 44 is the same way.
Old Nov 16, 2002 | 12:26 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Hey!
I've got Russel's braided lines on my car, I have the fronts installed, and I like the quality and fit of them very much, I haven't done the rear yet, but I do know that I only have one hose for the rear, while when I look over the lines out back I have the flex hose joining the main line to the junction block on the rear end and then I also have a flex line going to one of my rear calipers. It seems odd to me that I only have a flex line to one of the calipers, and a hard line to the other one, but what I am wondering is if anybody knows if I can get just the rear flex line by itself (the one to the caliper). Does Earl's have hoses available by length? Anyway, any suggestions are welcome!
Thanks!
-Paul
Old Nov 16, 2002 | 01:06 AM
breathment's Avatar
both my rears have a hard line running to them.. its so annoying to change the rear pads...
Old Nov 18, 2002 | 11:47 PM
Kandied91z's Avatar
yeah, i really loved my kit; just sold my fronts for an upgrade.
Old Nov 19, 2002 | 02:19 PM
camaro_1983_383's Avatar
Clem
In the catalog it says that installing these lines on a mustang shortened the stopping distance on a mustang by 18 feet.
Old Nov 19, 2002 | 03:09 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Originally posted by quadgoat
Hey!
Thanks!
-Paul
Keep an eye on those Russell lines. Especially the junction block on the rear line. If it's brass, it's prone to failure. Believe me, I know first hand.
As for the passenger side caliper flex line, I don't think anyone makes it. I had a custom one made using the factory fittings.
Old Nov 19, 2002 | 03:32 PM
AFreaknGoodTme's Avatar
I'm keeping very quiet on this subject this time I'm trying to keep this screen name for a record 2 months this time.
Old Nov 19, 2002 | 03:43 PM
Car: Yes...
Sounds like you're just as unhappy with Russell Performance as I am.
Old Nov 19, 2002 | 04:01 PM
Last time I tired to warn someone about Russells, we got in a debate and ended up getting banned from this site.
Old Nov 19, 2002 | 04:34 PM
quadgoat's Avatar
Car: 1992 Firebird
Ok,
Thanks for the thoughts....I've heard bad stuff about Russel's too, unfortunatley it was after I bought mine I intend to keep a close eye on them, but I was very satisfied with the fronts, and they seemed to be nice pieces. I will look the rear over before I install it, and maybe I'll just bite the bullet and spend the extra $$ to buy an Earl's line for the back. I dunno. Of course it was a local speed shop that got me the Russel's lines, and after I read some bad stuff about them on here I asked the shop (a friend of mine works there) and they said they've never had a problem with them, so we'll see Thanks for the advice though guys, no need to worry about a fight over Russel's vs. Earl's I won't start anything if you dont
Thanks,
Paul
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
