EFI to Carb....braking issue
Old Feb 16, 2005 | 12:20 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Switched to carb from HSR and I have lost some vacuum for the brakes. The hose from the booster is rubber, hard line and then rubber to the carb. The brakes are sometimes hard and stopping is difficult. Any ideas on a better way to do this? I have a Holley 750 dbl pumper. Thanks.
Old Feb 16, 2005 | 12:25 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
How much vacuum at idle? (More or less than after swap?)
Possible vacuum leak after carb swap?
You might try running hose to a fitting on intake manifold instead of carb.
Old Feb 16, 2005 | 12:46 PM
I dont know how much vacuum at idle. I have less than I did before. I will look at trying the intake idea. Does it matter where?
Old Feb 16, 2005 | 12:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your vacuum line runs from the booster to the carb with no other devices teed off of it?
Old Feb 16, 2005 | 12:52 PM
That is correct.
Old Feb 16, 2005 | 12:59 PM
Lo-tec's Avatar
Might want to get a vacuum gauge on it first. If you have less vacuum than before, might not be enough to operate booster.
A lot of intakes have threads in one of the rear runners or on the back side of the plenum under the carb to put a fitting in.
Old Feb 16, 2005 | 01:25 PM
I will check. thanks...
Old Feb 17, 2005 | 07:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If inadequate vacuum is present at the booster, try a vacuum resevoir.
Old Feb 18, 2005 | 12:46 AM
Looked for a port opening on the intake and the only one is in the front. My cam is really big and I have little to no vacuum. I will go with the reservoir. That will work for me.
Old Feb 18, 2005 | 12:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Out of curiosity, how big is your cam? A vacuum pump might be a better idea than a reservoir on a street driven car.
Old Feb 18, 2005 | 11:37 AM
Lo-tec's Avatar
I would definitely measure you vacuum at idle first to see how close you are. I have 13" @ idle and have no problems. You might be able to tweak carb mixture and timing at idle to bump vacuum enough to avoid canister or pump.
If you have to, I would also look into a vacuum pump instead of canister. Some of the turd diesel cadillacs in the early 80's had both electric and belt driven ones that should be easy to adapt. Check your local boneyard.
Old Feb 18, 2005 | 01:00 PM
I will check on my cam specs. I don't remember what they are. My buddy says that the motor was built to the point where there is almost no vacuum. I am going to try the reservoir. I think it will be adequate. Honestly, I only drive the car 4-5k miles a year. Work is only a little more than a mile from my house. The brakes work, it's just that they are hard at first and then normal and sometimes go back to being hard once in a while. Thanks for the input. I'll let you know how it goes. It should be done somoetime next week.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
