anyone know what prop valve # 14089497 fits
Old Apr 22, 2005 | 09:07 PM
wolffman007's Avatar
anyone know what prop valve # 10994901 fits
as the title says, its supposed to be a J65 for a 86-88 Iroc
thanxs
sry the title has the wrong part #, it should be 10994901
Old Apr 25, 2005 | 03:27 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
don't know about the 10994901 number, but the 14089497 is the proportioning valve that chevy sold me to do a drum to disc swap this past weekend.....
putting a 91 formula rear end up under my 88 camaro sport
Old Apr 25, 2005 | 03:56 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
14089497 is the correct # for 86-88 J65 brakes. The 10994901 # is a dud (not a good GM part #).
Old Apr 25, 2005 | 04:03 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
14089496 is the first edition Combination valve of the 1LE 4-wheel disc "performance package brakes" cars.
It fits the 1984or 85(?) - 1989 1/2 year cars. The same 1LE combo valve is used in the later 1989 1/2- 1992 cars but has a different finer thread pitch and a different part #, But the bais on the pre-89 1/2 and post-89 1/2 Combo valves are idential internally. This is the best valve to use even with the 10.5" non- performance package 4 wheel disc cars.
Old Apr 25, 2005 | 10:10 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
question for RTFC
Trying to put a rear end (actually already put) rom a 91 Formula with the J65 brakes on my '88 Camaro. Thje brake hardlines do not attach to the caliper...in that they will not seat since there is nothing for them to seat in.
What do I need to attach the calipers to my hardlines.
Attached Thumbnails anyone know what  prop valve # 14089497 fits-imag0025.jpg
Old Apr 25, 2005 | 10:12 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
Also
Another pic
Attached Thumbnails anyone know what  prop valve # 14089497 fits-imag0024.jpg
Old Apr 25, 2005 | 10:34 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
You can not attach a hardline to a floating caliper. GM actually did that with several loops in the hardline to the drivers rear only caliper on the smaller Delco-moraine caliper 10.5" factory rear disc setups. Yes just the drivers side on the rear. The passenger side had a rubber brake line from the hardlline to the caliper like they should. The drivers side is notorious for not releasing as well as the otherside due to lack of movement freedom with the hardline mount.
EdMiller should be able to give you more info on the fitting size of the PBR rear caliper you are showing and what part #'s are required to get it fitted properly. My setup is completely aftermarket and custom, but here's what I have
Attached Thumbnails anyone know what  prop valve # 14089497 fits-install7.jpg
Old Apr 25, 2005 | 10:39 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Finished picture
Old Apr 26, 2005 | 07:51 AM
Lo-tec's Avatar
There is a small rubber flex line that attaches to the caliper with a banjo bolt and two small copper washers. There should also be a small bracket on the rear that the other end of the line fits into with a U-clip (like the front brakes) and the hardline runs into that. I would see if you can find someone close by with the same setup to look at, or maybe someone on the forum can post picture. I would also consider getting braided stainless lines if you have none now.
Old Apr 26, 2005 | 08:02 AM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
So where can I contact EdMiller??
Did a search of forum and no EdMiller pops up.....
Talked to Chevy house yesterday about parts I needed (He said I needed the rubber hose setup already mentioned) and he is trying to locate the hose, banjo valve, crush washers, etc. He said the hardline to rubber hose adapter is discontinued....
Old Apr 26, 2005 | 10:47 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
I'm sorry. Ed Miller's callsign is EBMiller88
Here's his e-mail address.
ebmiller88@aol.com
Old Apr 26, 2005 | 03:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This link may provide some info:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Apr 26, 2005 | 03:27 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
OK...so basically I can get what I need from finelinesinc.com
BUT do they have the adapter/mounting plate where the hardline connects to the flex line to hold it all in place?
Piece that mounts on the axle to stabilize that junction?????
They are discontinued/not avail from GM
BTW sent EbMiier88 a PM ...waiting for a repsonse
Old Apr 26, 2005 | 03:34 PM
JamesC's Avatar
Keep reading the above until you reach brackets--I think that's what you're describing anyway
JamesC
Old Apr 26, 2005 | 03:56 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
JamesC you're right....all the info is there....just didn't read the 6000 lines of verbage....did a sesarch for brackets and found it.
Called Classic industries and ordered them...on B/O will be 2 to 4 weeks....
Oh well guess I can use radiator hose clamps to hold them stable until the brackets come n...
Thanks for "enlightening " me
Chevy house will have the rest of it tomorrow.....
Old Sep 15, 2005 | 08:49 PM
chesterfield's Avatar
Car: Pontiac
i got a proportioning valve# 10994901 off of a '88 gta with rear disc 9 bolt. hope this helps the next guy that searches that number.
Old Oct 31, 2005 | 10:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anyone got a number for a disc/drum prop valve?
Not listed for 86 anymore online.
Old Oct 31, 2005 | 10:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id be happy just to find a new seal rebuild kit.
Old Nov 1, 2005 | 05:27 AM
JamesC's Avatar
Gumby,
I've got a disc/drum pro valve from an 88. If you're interested, PM me.
JamesC
Old Nov 1, 2005 | 07:56 AM
Lo-tec's Avatar
GM part # 14089495 for an 86, list price $113.22
Old Nov 1, 2005 | 11:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Geese oh petes, you can't just buy new o-rings and seals somewhere? Even if not in a kit, by the indivdual part. Anyone got a microfish of a prop valve and part numbers? That is all that wears out. Knowing GM many year used the same internal parts. Maybe configed different but GM likes to parts bin things.
Good used parts can fetch 1/4 of retail price and even then you are taking a risk that it will not break till after you get it. Or do $20 you pull it crap shot.
Though maybe on a $20 u pull I could take the prop valves apart before I buy. Need a diagram for one though.
Old Nov 1, 2005 | 11:47 AM
Lo-tec's Avatar
Unfortunately, GM proportioning valves are not serviced that way; you've got to buy the whole enchillada.
Old Nov 1, 2005 | 12:06 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
And GM wonders why they are hurting for sales. When you can buy better name brand aftermarket parts for less then sock parts.................2+2=7 after GM markup
Gonna do the master cylinder and a super flush n bleed first.
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
1985chevydude
Aug 20, 2015 12:29 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
