e-brake cable removal
Old Oct 14, 2005 | 03:39 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
How do you get the damn thing loose of the brake backing plates? I'm trying to pull my whole rear-end assembly and this is the only thing holding me back.
I dont understand how those little clasps work.
Anyone got any tips??
Old Oct 14, 2005 | 03:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I bought a tool, which makes removal much easier. I was told that a zip tie could be secured around the 'prongs' to collapse them (much as the tool would do).
JamesC
Old Oct 14, 2005 | 04:01 PM
once you get a zip tie around them.....then what? Or...the tool you have...does it cause the prongs to fold in and then slide into the piece below it?
Old Oct 14, 2005 | 04:40 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Disc cables? I use needle nose pliers and pinch them in one at a time.
Ed
Old Oct 16, 2005 | 12:36 PM
no...i mean to get it off the backing plate for a drum setup
Old Oct 16, 2005 | 01:11 PM
ebmiller88's Avatar
They should be retained the same way...round thing with 3 spring clips around the outside. Pinch them in one at a time and pull out while doing it, that should work.
Ed
Old Oct 16, 2005 | 06:41 PM
thanks ....i'll give it a shot
Old Oct 16, 2005 | 07:03 PM
ebmiller88's Avatar
Oh yeah...make sure you disconnect the end of the cable first, don't know if you thought of that..
Ed
Old Oct 16, 2005 | 07:49 PM
88IROCARMY's Avatar
Okay
So the cables are disconnected fron the brake shoes?
The retainers have three prongs, pull and push down on each prong.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
