whats better.. 1LE or LS1 front brakes?
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
as far as rotor surface area.. and brute stopping power.. ? i have 1LE's with Hawks Ceramic pads.. and LS1 rears..
i use the car for spirited driving in the utah canyons and an occassional open road race every 6 weeks.. so far my 1LE's have been great.. i was wondering if the LS1's are better
Car: 91 Red Sled
What might be better for me might not be better for you. The LS1 calipers appear to be stronger (resist spreading) but at the same time they're heavier and have a different piston bores. This means swapping from 1LE to LS1 would change the balance between the front/rear... maybe for the better... maybe for worse. It's hard to say except I'd personally hold onto the 1LE's if they're working great for you! Why spend $$$ to convert? You might want to price out rotors for your next brake change. I bet the 1LE rotors are getting harder and harder to find. That's when swapping to a newer setup might make more sense.
Engine: 4.3 Turbo
Transmission: 4L60
well i wanted to see if there was a significant increase .. if its only minimal then no i wouldnt swap..
however.. if someone can make the CTS-V calipers work.. i'll swap in a heartbeat!
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I don't think you'll see a big difference in the two types of brakes, especially if yours are working great. I love my full 1LE car, stops like crazy.
Ed
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by va454ss
What's the minimum wheel diameter that can be used with the CTS-V calipers?
Ed
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
CTS-V brakes come stock under 18" wheels, but i have no clue about clearances. The rotors are supposedly <14.4". It would be the **** to fit CTS-V brakes but too bad they have 6 lug rotors. You might as well go C6 ZO6 brakes with 5 lugs.
I just need to know the diameter and thickness of the rotor that caliper lives with...I can use a different 5 lug rotor or a two piece rotor to get the size I need, not the Caddy 6 lug parts.
Ed
Ed
sailtexas186548
Jan 19, 2016 12:21 PM
