Brake problem
Old Mar 27, 2006 | 09:40 AM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
Brake problem
I don't know what is wrong with my brakes, but the front passenger side brake seems like they are not letting off the rotor. The rotor and pads are fairly new and are correct for the car. When I get out of my car after only driving down the street, I get out and smell a weird smell coming from the wheel well. I look at my passenger wheel and smoke is coming out and my rim is pipin hot. I don't know what the problem is. I think the caliper is shot because it must not be letting off the rotor. Has anyone experienced this too? I heard there is a quick fix to this, but I forgot what someone told me on here before. That was before the problem with the search feature so I cannot look up my old post. I worry my car will catch fire if I use it until I get the time to fix it, but I wonder what the problem is exactly.
Old Mar 27, 2006 | 09:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Brake line?
JamesC
Old Mar 27, 2006 | 10:22 AM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Do you mean the short, flexible on to the caliper, or different one?
Old Mar 27, 2006 | 11:13 AM
JamesC's Avatar
To the caliper.
JamesC
Old Mar 27, 2006 | 04:43 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Cool, thanks. I went to the store, they have reman. calipers for $9 a piece, plus $10 for the hose. I'm gonna replace those two and see if that fixes it. Thanks
Old Mar 27, 2006 | 06:51 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
yes, this is your caliper sticking. Definitly replace both fronts, and you should be good to go
Old Mar 28, 2006 | 09:50 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
I did replace the front passenger caliper today, test drove it, and it seemed fine. Although the next drive I took, which was only a few blocks away, it did the same thing again. It got hot as hell and smoke billowed out of the wheel well. I don't know what the deal is. My brake pedal is hard to push in, and it takes while for it to push in and pull out to normal again.
Old Mar 28, 2006 | 11:10 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Did you replace the rubber hose ?
Old Mar 29, 2006 | 02:33 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
No, just calipers. I looked at the hose and it is attached in matter I'm unfamiliar with. I don't have suffiecient tools with me now currently to take those off, but I will get some here this weekend. But would the hoses be the problem? You know what, when I took off my caliper, and disconnected the hose to the caliper, barely a drop of fluid came out. So I wonder if it is the hose. Do you think?
Old Mar 29, 2006 | 02:39 PM
JamesC's Avatar
The hose may be collapsing/have collapsed.
JamesC
Old Mar 31, 2006 | 12:42 AM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Finally! It was the hose. It's been great so far. I would like to replace the other side's caliper and hose too to be safe. Thanks alot everyone. I will let you know if anything comes up.
Old Apr 15, 2006 | 11:14 AM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
How did you get the hose off? What tools do you need?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
