Well PBR rear bakes still not working...
Old Jan 26, 2007 | 04:39 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Ok this is my last attempt to figure this out before I give up.
Here is the things I have done:
1. Earls Stainless Steel Lines
2. Fine Lines Stainless Hard lines
3. PBR rebuild install on the calipers
4. New GM 92 Z28 4 Wheel Disc Prop Valve
5. Power bled the system with a Motive Pressure Bleeder
6. All new synthetic fluid
7. New GM Banjo bolts
Brakes still do not stop the wheels from spinning at idle up on jackstands.
All thats really left I presume is so replace the calipers with complete new ones, master cylinder, or power booster.
My front brakes work fine. Fluid runs fine out the bleeder screws.
Any ideas? I am about to push the car off a cliff.
Old Jan 28, 2007 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sorry to hear of your on-going difficulties--gotta be frustrating. Did you ever experiement with "free travel"?
JamesC
Old Jan 28, 2007 | 09:15 AM
crrllmich's Avatar
Engine: L03, LS1
I thought the free travel was only for the ebrake?
Old Jan 28, 2007 | 09:37 AM
JamesC's Avatar
Could it be that if you adjust the free travel so that the e-brake functions as designed, the brakes themselves will work properly as well? Free travel, as I understand it, is pretty much a pad adjustment. At this point, you have little to lose with a bit of experimentation.
JamesC
Old Jan 28, 2007 | 09:40 AM
crrllmich's Avatar
Engine: L03, LS1
True one of the hex set screws happens to be stuck tho so gonna have to play with that... worst case I will drill it out , tap, and put another one in. I will post as to what happens.
Old Jan 28, 2007 | 11:39 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yep, try the fine adjustment like James mentioned. They rarely need to be adjusted this way but it can happen.
Ed
Old Jan 29, 2007 | 03:21 PM
crrllmich's Avatar
Engine: L03, LS1
I practicaly mashed the pads into the rotors and no go.
So new calipers, master cylinder, booster, or take it somewhere and get raped?
Old Feb 2, 2007 | 04:31 PM
player 88's Avatar
Engine: 360 .060 over TPI
pull off the caliper and but leave it connected. put a block of wood in the caliper, leave enough space fo rthe piston/pads to move, but large enough so the pisont doesn't come out. messy)
Push on the brake pedal and see if it moves. If it doesn't then it is forzeon or no fluid pressure is getting to the caliper. With a helper have someone press on the brake pedal (like manual bleeding brakes) and crack open each brake line fitting going to the rear. Start at the mastrr cylinder and work your way back. I think you will find that ther is fluid going to the prop valve but not out of it.
Then.................
It could be the prop valve too. I have seen the prop/sfety valve on GMs remained shut and only lets fluid go to front. You will need to bleed the fronts to release pressure on the prop/safety valve. Then bleed front to rear, alternating back and forth until the valve is centered. Then bleed like normal. It took me a while the first time it happened to me.
It prevents the fluid from running all out if a line fails.
Old Feb 2, 2007 | 05:58 PM
crrllmich's Avatar
Engine: L03, LS1
Only problem is the prop valve is brand new....and the stock one did the same thing. So I presume all thats left to replace is calipers, mastercylinder, and booster.
So I started with the calipers since the free travel screw was frozen in place.
I will have them monday I will post what happens.
Old Feb 4, 2007 | 09:41 PM
player 88's Avatar
To clarify, they are designed to that! It is not a failure of the prop valve, your was probalby OK. condition.
Try bleeding front to rear until you balance it out.
good luck.
Steve
Old Feb 4, 2007 | 11:09 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
just getting in on this cause I'm planning on doing something similar very soon.
Old Feb 5, 2007 | 01:00 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
try bleeding till all you get is new fluid out of them
i had the same problem until i bleed them now i just have a mushy pedel
but i also did a c4 front upgrade
my rear calipers make a creaking noise when when i push the pedal down but i got them used but i figured id use them till they freeze up but for now they work
also the stock master cylinder and the rest of the brake system wasnt designed to work with synthetic fluid so that could be the problem right there
use the ford dot 3 stuff it supposed to be better then normal dot 3
Old Feb 5, 2007 | 06:16 AM
crrllmich's Avatar
Engine: L03, LS1
I appretaite all the response. I am picking up the brand new calipers today.
I will throw them on. I have a motive power bleeder Ill throw that on and bleed the brakes till the front ones comes clean too.
Wish me luck.
Old Feb 5, 2007 | 06:19 AM
JamesC's Avatar
Originally Posted by crrllmich
Wish me luck.
I do. If I'd experienced all the difficulties you have, I might've pushed my IROC over a cliff!
JamesC
Old Feb 5, 2007 | 07:29 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
go get new calipers my experience with these if they are frozen they need to be replaced i once went thru the headache the your going thru i left it gravity bleed one time for 2 days and it still did it thats why this time when it goes back together itll have 4th gen stuff on it
Old Feb 6, 2007 | 02:06 AM
westlotorn's Avatar
Something to think about
Wish me luck.
The odds that two rear calipers failed at the same time are remote.
Sounds like a pressure problem. Fronts work fine? Must have a good Master Cylinder unless this system uses separate pressure feeds off the Master Cylinder the problem is in the Proportion valve. New or not.
Reading up is necessary to find out the proper way to center this system.
My son's 97 LT1 Automatic has the same issue just discovered. I will look into answers. I suspect a very detailed bleeding recomendation will re center the proportioning valve. GM must have instructions available.
Old Jun 10, 2007 | 10:16 PM
crrllmich's Avatar
Engine: L03, LS1
Re: Something to think about
I just wanted to post in here saying I finaly got them working. I replaced the master cylinder with a LS1 master and bled the brakes the old fashioned way with a second person.
Also got the new 1LE aluminum calipers on the back thanks to Ed.
Old Jun 10, 2007 | 11:14 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Re: Well PBR rear bakes still not working...
glad you got this fixed... here's a link to mine if you feel like reading:
https://www.thirdgen.org/forums/brak...ults-prop.html
I don't suggest this method, but it worked for me. There's a couple of other good ideas as well, including switching to the LS1 master as you did.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
