i have no rear breaks
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
why would i have no rear breaks? rear disc breaks on a drum car
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: i have no rear breaks
Did you just replace the rear drum braked rear end with a disk braked rear end?
its been that way for a few months had disc breaks but sunday had it on jack stands started the car and let the tires spin and pushed the breaks and didnt stop the tires
So, the the rear disk brakes were once working properly and now they dont? Please describe in more detail what led up to or may have caused this situation?
rear breaks have never worked rgt . i bleed the breaks no help.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
So the car came with drum brakes and you swapped to disks? If so, did you change the proportioning valve? Disks and drums require different pressure and volume of fluid.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
thats true, but they would still work to some extent. how are the flex lines? they may be collapsing.
If the parking brake is working ok, then thats the way they rear disks work. If the parking brake isn't working, fix that first.
proportioning valve where can i buy that
GMPartsdirect.com or a GM dealer
Read:
https://www.thirdgen.org/forums/brak...od-better.html
Even if everything else is ok, the stock rears will not lock.
hectre13
Dec 11, 2023 08:14 AM
