Prepping Next Brake Mod: 10-bolt drums to 9 bolt PBR's
Old Jan 27, 2008 | 08:43 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Hey gang,
I've been reading up on this swap for a while and you know I know better than the ask a question and not search on it first but here's where I am at with this. I have the whole axle (9 bolt 3.27 with PBR's out of an '89 GTA) and will be scrapping the 10 bolt that's on there now.
I'm collecting the parts to make the swap in the next month or two and so for I have collected:
  • New MC with Prop Valve
  • 9-bolt Gasket, Mobile 1 Syn Oil, GM Posi Additive
  • Ebake cable: Part # BC93132
  • Brake Pads
There are other parts and plans I won't bore you with...
My first question that may or may not be a rehash in some other thread is about the ebrake cable(s). Is there more than one? It looks like there is a the one from the handle on the console that actuates the two others that work the brake calipers. Are there part numbers for those?
Also... JamesC (esteemed brake master) second question: I got a lot of mileage out of THIS THREAD and want to know if you HIGHLY recommend the ebrake guides shown in one of your pics?
Last question is related to the attached pics. Is there supposed to be a lever for the ebrake cable on both calipers? Notice my finger on the lever in the first picture but the same part is missing on the other side. Do I need to locate some addition parts?
Thanks for the help TGO kin!
Attached Thumbnails Prepping Next Brake Mod:  10-bolt drums to 9 bolt PBR's-dside.jpg   Prepping Next Brake Mod:  10-bolt drums to 9 bolt PBR's-pside.jpg
Old Jan 27, 2008 | 09:50 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: Prepping Next Brake Mod: 10-bolt drums to 9 bolt PBR's
I hope you can fine someone to iunstall that who knows what the heck they are doing.
Old Jan 27, 2008 | 10:27 PM
Cadillac's Avatar
Yeah. Don't want any slackers working under my car or something.
Old Jan 27, 2008 | 10:34 PM
Comp788's Avatar
Keep the slackers away!
It does look like your missing a part for one of the calipers. Where is Ed Miller???
Old Jan 27, 2008 | 10:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
South Carolina..what cha need?
Ed
Old Jan 27, 2008 | 10:56 PM
Comp788's Avatar
Ed
Ed,
If you look at the picture it looks as if one of the actuator brackets for the e-brake is missing from the caliper. Is this a bolt on part or does Cadillac need a new caliper? Do you have any of these parts if it is a bolt on part?
Old Jan 27, 2008 | 10:57 PM
ebmiller88's Avatar
Originally Posted by Cadillac
Hey gang...about the ebrake cable(s). Is there more than one? It looks like there is a the one from the handle on the console that actuates the two others that work the brake calipers. Are there part numbers for those?
Also... Is there supposed to be a lever for the ebrake cable on both calipers? Notice my finger on the lever in the first picture but the same part is missing on the other side. Do I need to locate some addition parts?
Yes, to be totally correct there are 3 e-brake cables, one in front and two on each side to the calipers. I have numerous PNs for those and will post them up in the AM.
You are missing one of the cable levers on the caliper or the tip broke off. This is common if the rearend is placed on the ground and not supported. You won't need a whole new caliper but they are hard to locate all by themselves. I do have extras on hand (as usual) so if you'd like one, LMK via PM and I'll get back to you soon.
Ed
Old Jan 27, 2008 | 11:14 PM
Cadillac's Avatar
You have a PM.
Thanks Ed!
Your loyal customer,
Cadillac
(Mike)
Old Jan 28, 2008 | 05:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm afraid you have me confused with Ed . The guides are cheap insurance against cable/exhaust problems. IIRC, Ed recommended/used a system using "S" hooks. Maybe he'll throw in a pic.
JamesC
Old Jan 28, 2008 | 02:49 PM
Cadillac's Avatar
Aight... I got the other ebrake part numbers:
BC93215 and BC93084. These are on order and should be here this week. Each of the three part numbers is a different cost. Strange.
I also picked up some Raybestos semi-metallic brake pads (#PGD413M) Here's another shot of the side with the missing piece.
Attached Thumbnails Prepping Next Brake Mod:  10-bolt drums to 9 bolt PBR's-missinglever.jpg
Old Jan 28, 2008 | 10:44 PM
ebmiller88's Avatar
JamesC
I hold James in high respect as well, he knows his stuff.
The "S" hooks I mentioned are the stock style as seen here:
The 4th gen cable retainers can, in certain cases, strain the cables and give you issues. Honestly, I don't recommend installing them on a 3rd gen to avoid this problem.
Ed
Old Jan 29, 2008 | 09:30 AM
Cadillac's Avatar
Thanks Ed. Brett and I will skip it and play by ear.
Thanks for the PM! I know you are busy.
Old Jan 29, 2008 | 10:04 PM
Comp788's Avatar
Mike,
Were still on for Saturday?
Old Jan 29, 2008 | 10:45 PM
Cadillac's Avatar
If I can get that axle in my wagon we sure are. Early afternoon was it? I'm planning on calling you Friday evening still...
Ed found the caliper lever. Bought and paid for and just waiting on the shipping. The boxed control arms cleaned up nicely.
Old Feb 1, 2008 | 10:32 AM
Comp788's Avatar
Mike that will work. Talk to you then.
Old Jul 28, 2008 | 06:25 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Ed
Ed, I'm missing these "S-hooks"/guides on my 89, where can I get hold of a pair (I take it they are on both the driver and passenger side right? Can you help me with a pair if so e-mail me directly jlarsson@london.com any help much appreciated.
Regards,
Jan
Old Jul 29, 2008 | 11:43 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
what do you guys do for brake lines?
Old Jul 29, 2008 | 02:59 PM
JamesC's Avatar
Earl's braided.
JamesC
Old Jul 29, 2008 | 03:51 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Earl's braided.
JamesC
I meant from the junction to the calipers..or does the braided lines connect straight from the line (connected to the cylinder)straight to the caliper(I doubt)
Old Jul 29, 2008 | 05:25 PM
JamesC's Avatar
hard lines from finelines, IIRC, then braided the calipers.
JamesC
Old Jul 29, 2008 | 07:59 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Im thinking of making ones myself?Anybody have specs?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
