Earl's braided brake Problem!!!! Help!
Old Mar 25, 2008 | 11:04 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
I went to install the Earl's braided lines I got from Summit today. After putting it on, I checked for rubbing and found it was rubbing the bolt heads for the strut.
Did anyone else have this problem???? Can I fix it or should I send them back? Stick with rubber?
Any input would be helpful!!
Old Mar 26, 2008 | 05:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Earl's braided brake Problem!!!! Help!
Did you reattach the line to where it mounts on the strut?
JamesC
Old Mar 26, 2008 | 10:37 AM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Yes I did. But in the pic it is not becasue I took the bracket off the strut to see if a spacer would help, but it didn't so it is sitting there loosely.
Old Mar 26, 2008 | 10:44 AM
JamesC's Avatar
What kit did you purchase? Here's a link to Spohn's site that shows the various applications:
http://www.spohn.net/?action=shop&pcid=1082
JamesC
Old Mar 26, 2008 | 10:52 AM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
The box has on it "84-87 Camaro w/4whl discs, 88" I have a 1986 Firebird T/A with disc/drum. Summit did not sell a disc/drum setup so I thought I would just have one extra line. SO there are different lengths or something?
Old Mar 26, 2008 | 11:03 AM
JamesC's Avatar
Yes, for some applications at least. However, there may be design differences as well. Long ago when I did the Earl's upgrade on my four-wheel disc 85, there was an OE clip of some sort that had to be retained (IIRC). Later, when I went 1LE, that clip was no longer used.
JamesC
Old Mar 26, 2008 | 11:05 AM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Ill try that.
Old Mar 26, 2008 | 09:31 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
In your first pic, your line mount is installed incorrectly, it should be horizontal after it's tightened down. Try that first.
Ed
Old Mar 26, 2008 | 11:42 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Ed
Above the pics I stated that I had tried it with it on correctly the first time, then I tried putting a spacer on it and moving the bracket around. It all had the same results. It rubbed.
Old Mar 27, 2008 | 06:48 AM
ebmiller88's Avatar
I skimmed that part and missed it. The line should be retained tightly so it won't really rub since it won't be moving in that area. My lines are the same and are tight from the caliper to the retainer, I don't think it will cause you any issues. Also, keep the braided lines, going back to rubber lines would be a downgrade. Good luck.
Ed
Old Mar 27, 2008 | 10:07 AM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
They are right against the bolt they will be rubbing. They were not taught at all. A big arch. With the steering in certain positions it hit both bolts. I agree it would be a down grade, and I want a lot not to send them back, but they touch the bolts so much, is there anyway for me to move them out, or make them taught?
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
