replacement calipers
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
I need to replace my front calipers on my car. Everything is stock so far. I saw the Bendix calipers on Summit for about $35 bucks.
http://store.summitracing.com/partde...5&autoview=sku
.....Will these be a direct bolt on replacement? I know some people r going to say that I should just upgrade to 1le's or what not, but Im assuming that would be a lot more expensive.
Re: replacement calipers
Sure; except for one thing:
Costs 3½ times as much as buying em down the street.
http://www.autozone.com/N,14400852//...eResultSet.htm
One of the cheeeepest parts on the whole car. There's NO EXCUSE for not having good ones on the car at all times.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Yeah, but the one he listed is a dual piston caliper. The stock ones are single piston like mine, right? (or does the IROC have the better brakes?)
I did see somewhere that sold a dual piston caliper that was supposed to be a direct replacement for the single piston one. Not too sure how much good it would do, with the small pads and small rotors though...
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Image is a representation of this part. Actual part may vary.
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Yeah im almost certain that its a single piston...the pic they posted is just for looks, but I am figuring that the Bendix ones r better than the ones on the Autozone link that sofakingdom sent me.
They're all "rebuilt". Same part. Kind of like, either it IS a Saggy caliper, or it ISN'T... not a whole lot you can do to make one "better" than another.
But hey, it's your money; go for it if you want. There's nothing wrong with it, it's just an awful expensive way to get no additional benefit.
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
yeah u have a point sofakingdom....all this crap is the same thing...i just need replacements....think ill go with the cheapest local ones. thanks
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i got dorman replacement calipers BRAND NEW zinc plated from the parts store i work at (auto barn). they were $35 each retail and i got them for $20 each with the employee discount. not a bad deal considering they came with all new hardware (new caliper bolts and all)....i'm sure you can find them online somewhere.
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Actually I took Sofakingdom's advice and went to Autozone last night. I bought Raybestos rmfd. calipers for 39.00 and they were loaded with brake pads and new bolts. Oh and there was an $11 core charge. So really it was only 28 bucks a piece. I forgot to ask but I wonder if they have the rears also.
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
