Big Cam No Breaks? Go to Manual Breaks??
Old Apr 5, 2009 | 01:06 AM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Some of you might know that Im building my car again..Im geting closer everyday. Iv got a healthy small block with a big cam and Im going to have an issue with breaks. I was going to do a hydroboost system..but not going to have power streering anymore. Worryed about a canister not being enought?? I know how old school cars are with man. breaks are..not a fan...if I was to convert mine to manual breaks would I like it or would it be the same as an old 60s-70s car? I need help! Is a vacuum canister the way to go or what?
Old Apr 5, 2009 | 05:36 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Big Cam No Breaks? Go to Manual Breaks??
What cam r u running, what are the specs, thought I may have problems but did not. I am runnung 548/ 548 dur in the 230s
You can always get an aux. vacuum pump...
Old Apr 5, 2009 | 10:13 AM
87_GTA_5.7's Avatar
262/262 intake/exhaust and .630 lift..I think I want to go with manual breaks but Im not sure if Ill like it..
Old Apr 5, 2009 | 10:55 AM
J91's Avatar
J91
That's alot of lift/dur, you may be ok?? I would try it and if not enough vacuum, get a pump. Jegs or Summit have many kinds of kits available. Make sure you get a street kit that'll hold up. I doubt if you'd like the manul brakes either...
Old Apr 5, 2009 | 12:04 PM
87_GTA_5.7's Avatar
Id like to know if anyone has converted to manual breaks just to see..its a street car but wont be drivin much unless someone calls me out..mostly drivin to car shows..
Old Apr 5, 2009 | 03:41 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
I have converted mine to man. brakes. I haven't finished the car yet to bleed them though. Here is the thread I started on the conversion. https://www.thirdgen.org/forums/orga...al-brakes.html
Old Apr 22, 2009 | 12:00 AM
86irocterror's Avatar
get a vacume canister. easy to install just vac line from engine to canister and to the brakes.
Old Apr 23, 2009 | 03:12 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I would go with hydroboost. I started mine but have a LOOONG way t go. The pump I am using is from an 05 gmc savana full size van. The master cylinder bracket fits perfect on the hydroboost flat plate bracket. then cut off some of the master cylinder pedal rod (I cut off about 2.5") and then run the rod through a fine thread die cut off some of the hydroboost pump rod and thread that and get an adjust with the same threading as the die then install it. (I still have to cut the rod off of the hydroboost pump and thread it but it is fairly straight forward) This way as long as you keep power steering you will have brakes. PM me if you need any help or part #'s if you are interested.
Old Apr 23, 2009 | 11:03 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Well we are going to run across each other pretty soon since I live in Nixa and frequent rogersville as often as I can. I also have a 3rd gen N/A SB with simular dims. 262/266@ .050 and 106LC . I have been using a canister for along time and have had no problems with lack of vacuum for breaking. So If you want to use one to just get the car running, go for it . then change if you like to a pump later on.
Old Apr 23, 2009 | 11:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
electric vacuum pump by ss bc runs only ~280..
Old Apr 24, 2009 | 12:19 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I know I would never rely on a cam that size to do anything for my brakes, but I also like to idle my motors low. I have a 264/271 dur@ .050 .626/.626 cam and idle it about 700-800rpm where it makes all of like 4-6" of vacuum. I'd go for either the vacuum pump, or manual cylinder with LS1 or C5 stuff at the tires. My manual master sucked on the stock brakes, but with the LS1 stuff on there now it is much more liveable.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
lt1z350
Aug 28, 2015 05:57 AM
bdads
Aug 24, 2015 06:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
