cross drilled rotors
Old Aug 9, 2009 | 09:10 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
I need help with rotor replacement. I am replacing my rotors and noticed the R1 concepts on ebay. They were very cheap priced compared to the others. Anyone have any experience with them? I noticed one consumer note on the web that they rusted in one day after purchase. This is common on a rotor anyway isnt it? Is there a popular brand recommended for these rotors? And experience with ceramic rotors? I dont know if I can replace with larger ones and stock calipers or other simple upgrades. I need to keep it inexpensive.
Old Aug 10, 2009 | 06:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: cross drilled rotors
You can't go larger with stock calipers. Personally, for a daily driver, I'd simply replace with an OE version, new pads and lines.
JamesC
Old Aug 10, 2009 | 03:18 PM
TA-Rocks's Avatar
I will be considering using the brakes from another salvage 4th gen bird in the future anyway.
So should I get the cheap r1concepts from the ebay? Is there any problem goin with some of the cheaper brand crossdrilled rotors? any suggested brands?
Old Aug 10, 2009 | 05:41 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Check the feed back? Jegs//Summit,SSBC may carry them. Ya-price does play a part on what we buy. PLEASE think before you buy! If you feel confident with the info then get them & recommended pads. Powerslot makes slotted//drilled, & just slotted. Good luck & post your install!
Old Aug 10, 2009 | 07:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
cheap ebay parts are usually Chinese parts, which means soft crap steel. I would pass on them. No real benefit to drilled rotors at this point, besides, if you want to use the 4th gen stuff later, you have to cut up your drilled rotors to make the new floating hubs.
Old Aug 10, 2009 | 09:32 PM
TA-Rocks's Avatar
good then. LoL thanks. I will do the stock and replace the hoses then too. Thanx guys
Old Aug 15, 2009 | 04:58 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If you plan to upgrade at any time, save your old rotors to have them cut down to just hubs.
Old Aug 22, 2009 | 11:53 PM
Pocket's Avatar
Car: 91 Trans Am
4 years on my R1 rotors and it took an Ohio winter to make the cooling fins rust
The zinc washed hub still looks new
Dont buy them for any performance or looks improvements. If you want cheap replacements for your daily drive thats driven as such then get them
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
loud91rs
Oct 5, 2015 10:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
tattmann
Sep 27, 2015 05:20 PM
indygene
Sep 26, 2015 11:21 AM
