front brakes stuck?
Old Aug 20, 2009 | 10:51 AM
cutmesomeslack's Avatar
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
front brakes stuck?
OK Ive been going over smaller things before I swap my engine and my front brakes are pressed completely up against the rotor and i can hardly turn the wheel. Also if i go to press my brake pedal it is really hard and only goes down just a little and no further no matter how hard i push. the car has been sitting for about 6 years and when I pulled it home behind my truck it rolled OK and my back brakes seem to be ok and i can turn the drums. I have done a search and couldn't find another thread with this problem. Where are the valves to bleed my back brakes? Is it there the white cap is above the brake line on the backing plate? there is nothing there when i take the cap off.
Old Aug 20, 2009 | 05:48 PM
Engine: Carb'd 350
Axle/Gears: Stock
Re: front brakes stuck?
can someone help i really need to get everything fixed before i swap my engine because it will be the only thing i have to drive
Old Aug 20, 2009 | 06:22 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If your front brakes were stuck, you wouldn't be able to turn the wheels by hand. If the car has been sitting for six years, the rotors are probably just rusty, making the wheels difficult to turn, nothing to worry about.
Is the brake pedal hard to push while the car is running? Brake pedals are hard to push on all vehicles with power brakes while the vehicle isn't running.
The bleeder for the brakes is right above the brake line on drum brakes.
Old Aug 25, 2009 | 01:49 PM
wolverine350r's Avatar
Car: 91 TA WS6
Transmission: Auto :(
Just make sure it is the brake holding it, not bad wheel bearings...it has been sitting a while after all.
Old Aug 25, 2009 | 04:04 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
a common enough problem , could be all of the above . BUT , more likely than not it's front flex brake lines . they collapse internally and act like check valves . not allowing press. to relieve . ( happened to me ) remove lines & replace . note that they are keyed to mounting brackets lt. & rt. . ( another , it happened to me ) i ended up buying 3 instead of 2 . you may want to consider changing the rear flex line also . good luck .
Old Aug 25, 2009 | 04:19 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I just solved this problem on my new IROC vert, that had sat for 11 years. Front right brake was stuck, I had to beat the caliper off of the rotor with a hammer, literally like 30-50 smacks. I replaced both front rubber lines, calipers, and new pads, and bled the system now it works flawlessly. Calipers are cheap enough, around $10 with a $10 core, not bad, always replace in pairs.
Old Aug 26, 2009 | 03:36 PM
Engine: Carb'd 350
Axle/Gears: Stock
thanks for the reply's. I am thinking it is the front flex lines that are my problem so I will replace them.
Old Nov 12, 2009 | 10:35 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
thats good to know. i bought one caliper, good point to replace both. but im going to try one first see if it helps. but then replace the other one. did you get your calipers at autozone?
* i replaced the master cylinder. it was bad. but its good now
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
