Wheel studs for Weld Pro Stars?
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
I pulled my rotors off today to repack the bearings and I saw that two studs have been replaced on the pass. side. Although I never had a problem I think it is a good time to replace all the factory studs with longer ARP ones.
Should I use 1/2" or 12mm?
Press in or screw in?
What length?
Open or closed lug nut?
The rear is already done with Moser 3" long 5/8" studs.
Could someone point me in the right direction?
What length?
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Re: Wheel studs for Weld Pro Stars?
Well... I ordered from Summit Racing today. I hope I got the right ones. I ordered ARP-100-7708. I think they are one inch longer than the factory ones.
Car: `86 SS / `87 SS
Those are right; 2.5" long.
GM 22551491 is 2.9x" long but I don't know if that's thread length or total (there's a bit at the end that's unthreaded)
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
jmd, you told me to buy .769" long shank the other day. I havn't tried them yet, since im not near my car, but I hope they fit.
edit..
yeah.. it said studs. Didn't catch that. I thought it said lug nuts. Well it did but thats not what he was talkin about.
Sorry bout that
edit..
yeah.. it said studs. Didn't catch that. I thought it said lug nuts. Well it did but thats not what he was talkin about.Sorry bout that
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Hey red, what is the shank legth on your lug nuts? It doesnt matter if its with or without the washer.
thanks
thanks
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I'm glad I bought the right ones.
lug nuts are 1 1/8" long measured with out washer. Wheels are 1 3/8" thick.
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I can't remember the color for sure, but they are genuine Weld wheels.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
