pulling to one side
Old Mar 11, 2010 | 12:17 AM
built's Avatar
Car: 82 TA
pulling to one side
My car pulls to the right bad when applying the brakes, does that mean the right front caliper is bad or going bad ?
or can rear brakes make this happen too ? they need changed i think but having a hard time getting the drums off.
Old Mar 11, 2010 | 12:21 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: pulling to one side
If anything, it means the left is going bad. Basically the right side is stopping and the left side is trying to use the right tire as a pivot point.
Bad rear brakes can cause it, but its almost always the fronts that cause a pull.
To try to get the drums off, if they will come off a little, try spinning the drums while pulling them off. If that doesnt work, sometimes there is a rubber plug you can take out of the backing plate and loosen the adjuster.
Old Mar 11, 2010 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by built
My car pulls to the right bad when applying the brakes, ...
Common problem when the brake hose collapses internally and acts as a check valve.
JamesC
Old Mar 11, 2010 | 10:37 AM
built's Avatar
Car: 82 TA
from the backside, which way do i want to move the star wheel.
Old Mar 11, 2010 | 11:15 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
JamesC
+1
Its almost always this.
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Simple things first...Replace the rubber brake hoses. Thaty is the problem.
Old Mar 11, 2010 | 11:21 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Brake hoses, been there too.
Old Mar 12, 2010 | 12:21 AM
built's Avatar
Car: 82 TA
I replaced one a couple years ago but i don't remember which one, that one was cracked and looking bad.
Is there a way to tell if one is blown on the inside?
Is that correct that if it pulls to the right that means the left hose is bad ?
The back brakes are not making any noise but i figured it was about time since i replaced the rotors and pads and the one hose two years ago on the front but maybe i can get more out of them and just replace the front bad hose if I can locate the bad one .
Old Mar 12, 2010 | 06:12 AM
DJP87Z28's Avatar
When working on brakes, you replace by sets on both sides. Your example: replaced "one brake hose", you should have replace both. then Then you wonder what the problems are.
Old Mar 12, 2010 | 06:13 AM
JamesC's Avatar
The hoses can look fine and yet be faulty. Most members would tell you to replace the hoses in pairs.
JamesC
Old Mar 13, 2010 | 12:33 AM
built's Avatar
Car: 82 TA
yes i should have but money was real tight and i was forced to just replace what i had to.
I'll try and look at it this week when it stops raining.
Any tips to help me look for anything?
Old Mar 16, 2010 | 08:06 AM
Perpendicular's Avatar
Where is everyone getting the hoses?
Old Mar 16, 2010 | 08:10 AM
JamesC's Avatar
Welcome to TGO. Any auto parts store will either have them in stock or be able to order in.
JamesC
Old Mar 16, 2010 | 08:23 AM
DJP87Z28's Avatar
If you want to upgrade, replace with Stainless Steel hoses. Better brake feel and will last the life of the car (in most cases).
Old Apr 11, 2010 | 06:51 AM
built's Avatar
Car: 82 TA
replaced both front calipers and hoses and all is good now,thanks.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bert87
Aug 23, 2015 03:50 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
