new prop valve doesnt fit?
Car: 1987 IROC Z
hi, i just bought a new wilwood combination proportioning valve and had everything ready to install when i found out the flare nuts provided are not big enough to fit over the stock lines.
http://www.jegs.com/i/Wilwood/950/260-11179/10002/-1
can i buy new flare nuts that will fit or am i in need of a different part?
not to mention the two wire connection i just noticed. my car has only 1 wire to the brake switch. is there anythin i can do?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: new prop valve doesnt fit?
the stock brake switch is a warning switch to tell you there is a problem with the braking system. The switch on the wilwood setup is a regular switch to turn the lights on.
You should be able to get the proper sized flare nuts at most auto parts stores, napa usually has a good assortment.
Car: 1987 IROC Z
do they have multiple tubing sizes with the same thread? i know that the front tube off the master cylinder is like 3/16 but the fittings they gave me r to small.
thank you
thank you
Car: 86 Trans Am
the small lines are eiter 3/16 or 3.75mm. the large line for the rear is 6mm. The fittings on the car are bubble flare, so you either have to cut and replare everything to inverted flare to match the prop, or try to find adapters of some kind, not sure exactly what you are doing. The fittings on the car are metric threads, the small fittings are very close to the inverted flare 1/8-27 npt sizes, but THEY ARE NOT THE SAME! do not put them together.
these guys have a lot of crazy bubble flare fittings, and other kinds as well.
http://www.fedhillusa.com/
the fittings that came with the valve are probably SAE inverted flare fittings, not the prop bubble flare ones.
Car: 86 Trans Am
i saw that prop valve in the jegs catalog the other day and its pretty cool, i owuld like to see what the install looks like when you are finished.
Car: 1987 IROC Z
the difference in size of the tubing and fitting wasnt anything huge so i got the right size drill bit and drilled it out. idk how much pressure there is in the lines but we'll see what happens. unfortunately the flare tool i bought sucked and i dont have time to run out and get a new one right now so ill finish tomorrow probably and post up pics of it finished.
thank you
thank you
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Axle/Gears: 10 bolt 2:73 Posi
i just installed mine earlier today, install was a breeze with no re-flaring at all. I have pics and part numbers if anyone is interested.
Car: 86 Trans Am
post them up! not sure how you did it with no flaring of anykind
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Here goes, please excuse the wire mess, engine swap/efi install in progress.
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
I used some adapters from auto zone with the correct fitting and flare with compression fittings on the outs and 3/8-24 to 11 x 1.5 8" adapters for the 2 lines going from the master to the prop valve. I only had to bend those 2. I even reused the stock prop valve mount with a little modification.
Car: 86 Trans Am
how did you attach the large rear body line to the valve?
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Car: 86 Trans Am
compression fitting? is that rated for brake pressure?
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I'm still unsure as to why I need a proportioning valve for my 4th gen disc rear swap. I never did this kind of a swap before.
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 86 Trans Am
Car: check
Engine: check
Transmission: check
According to Wilwood the fittings on that proportioning valve are -3 I.F.
http://wilwood.com/MasterCylinders/M...derValves.aspx
{edit: I take back what I said about the fittings being incorrect. In the drawing Wilwood specs them to be -3 fittings. Which is AN 37* seats.
In their instructions for that valve they claim them to be 3/8"-24 SAE I.F. fittings. Which is the same as the tube nuts supplied. And for a standard 3/16" double flared line.
Confusing to say the least. }
RBob.
RBob.
Car: 92 Z28
Car: 1995 Formula
Engine: LT1 350
Can't a guy just install the prop. valve at the rear end, on a 4th gen rear end, where that "T" is at?
Wouldn't that be easier (I have the 4th gen rear sitting by my fence--he he--so install would be a breeze)? Does it NEED to be right below the master cylinder?
Car: check
Engine: check
Transmission: check
After the initial install need to test the front/rear balance and adjust it. Which may take several iterations. Then if pad compound is changed, or even tire diameters changed, it may need to be re-adjusted.
RBob.
ambainb
Apr 25, 2016 09:21 PM
