lt1 master cylinder
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
lt1 master cylinder
i picked up a 95 camaro z28 brake master cylinder which i planned on putting in my third gen mainly because it looks alot better than the stock 3rdgen unit. The difference between the two is that the line output to the prop. valve for the rear brakes is a bit smaller. Does anyone have any experience with this or do you think the difference in the hole size will restrict pressure/flow. I have rear disc brakes.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: lt1 master cylinder
not sure, but usually the 4th gen masters people use, my self included, are from the ls1 cars since the threads are the same as the 3rd gens cars. Dont think the smaller line will hurt performance at all since it did work for the lt1 cars just fine.
i guess i will just have to go to the parts store and hope they have a brake line with an end for the porportioning valve and one for the master cylinder with the right size/threads
Car: '88 Camaro (Gone...)
It would probably just be easier to get a master cylinder for an ls1 car wouldn't it? (Just my opinion...)
You could probably take your lt1 master in to someplace like autozone, and trade it as a core for a re-man ls1 master cylinder *cough* They don't tend to check those things very closely at the parts counter. But you didn't hear that from me, lol
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
When I put LT1 masters on both my cars I used the stock rear line (front line on master) cut it, and used the tubing nut off the LT1 line and made a new bubble flare and was set. Worked perfectly for me both times.
Usually you can rent the flaring tool from a parts store.
Take a look at a late model C6 Corvette looking MC that works perfectly in these G-body and F-Body systems – same brake line sizes / thread pitches / port locations so that you can plug n play without hassles!
Raybestos MC390572 about $99.95
Try Matt's Classic Bowtie
Car: check
Engine: check
Transmission: check
RBob.
