A few 4th gen rear brake questions
Old Jul 5, 2011 | 07:31 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Couple questions about the rear flex lines, bleeder screws, and brake tee.
How do the flex lines bolt up to the calipers? One side of the flex line has a notch; which I thought was the side that faces the caliper, as shown in the pics. Ive got them flipped for the time being, as the car wont be up and running for a while.
The bleeder screw is suppose to be above the banjo bolts when mounted on the car correct?
Any one have a picture of how the brake tee is bolted to the rearend housing? I think Ive got it upside down but the bolt will only fit through the tee one way.
Attached Thumbnails A few 4th gen rear brake questions-img_2613.jpg   A few 4th gen rear brake questions-img_2614.jpg   A few 4th gen rear brake questions-img_2615.jpg
Old Jul 5, 2011 | 07:32 PM
Rich92 RS's Avatar
Transmission: T56's
Re: A few 4th gen rear brake questions
bleeder screw position
Old Jul 5, 2011 | 07:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is this a 1993 - 1998 rear (LT1), or a 1999 - 2002 rear (LS1)? Not sure it matters, but that was my first thought (as I have a LS1 rear in my 1992 car, and a LT1 rear in my 1997 car) - I could maybe get pics tomorrow.
Old Jul 5, 2011 | 08:17 PM
Rich92 RS's Avatar
Transmission: T56's
lol I completely forgot I drive a 98z28. If no one knows I'll check out my car tomorrow. Thanks for the offer though, I appreciate it.
LS1 rears run from 98-02.
Old Jul 7, 2011 | 08:40 PM
Ross85Camaro's Avatar
Car: Working on an 85 Camaro.
Engine: Hopefully 383 Stroker
Transmission: Will be a Power Glide
Axle/Gears: Undecided, thinking 411's maybe?
Can I hijack this post? lol I was thinking about putting a 4th gen rear into my 3rd gen. The price is right and it comes with Disc breaks! So how is that going to change my backspacing for my wheels? I was going to use a 6.5 bs on the original rear, but I hear this 4th gen is 2" longer on both sides?
Old Jul 7, 2011 | 08:52 PM
Car: 1992 RS
Engine: Carbed 350
Well, the LS1 motor was 1998 - 2002. But I call the LS1 rear the one with the Zexel Torsen posi unit, which didn't start until 1999 from what I read. Never thought about the brakes and what size discs are in a 1998 rear.
And yes, the 4th gen axles are just under 4 inches (total) wider, so the wheels will stick out not quite 2 inches farther each side.
Old Jul 28, 2011 | 02:33 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
You can put the center in your existing rear if you have 28 spline axles.
Old Oct 15, 2011 | 05:32 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
great. i just looked at that picture and it looks like im missing a bracket.
Old Oct 19, 2011 | 11:15 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
You're missing the parking brake/hose bracket. And because you have LCA relocation brackets, you'll have to cut/weld them to make them work.
They usually straddle the factory LCA mount, but because of your relocation bracket the brake bracket has to be widened so it'll fit around the LCA relocation bracket.
Here's what it looks like from the back:
from the front:
After I modded mine:
Are you using oem hoses? Mine fit 90* from the way you have them pictured, and the little lip is facing away from the caliper. Hope this helps.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
