12 bolt brakes
12 bolt brakes
I just got a moser 12 bolt for my 92 firebird and I was hoping to use my factory disc brakes but the bolt pattern does not match the new rear. Does anyone know if someone out there sells the brackets for this combination? Maybe I should just pick up an 93-97 setup or something. Any suggestions?
Re: 12 bolt brakes
Depends on which brakes you have, and which bolt pattern your new rear has, and in what way your stuff doesn't fit the rear.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 12 bolt brakes
JamesC
Re: 12 bolt brakes
The new rear has an even rectangular pattern and the 10 bolt is uneven, the bottom bolts are closer together then the top. I am thinking I will just have to make a bracket or something. Do the 93-97 cars have a 12 bolt or a 10 bolt?
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Re: 12 bolt brakes
if you bought the rear new from moser, i'm sure they will tell you which brakes it was set up for....i was recently talking with them about ordering a rear for my own car.....they can send it out for stock ( PBR) brakes or "other kinds".............how was it ordered?
Re: 12 bolt brakes
I am checking on how it was ordered now. It was supposed to be ordered to fit my stock brakes.
Do the 98-02 cars have a 12 bolt? Also, Do you know what PBR brakes come with mounting brackets?
Thanks!
Thanks!
Re: 12 bolt brakes
JamesC
Engine: Lt1 in IROC
Re: 12 bolt brakes
well i haven't tried it out yet, BUT my local camaro expert told me that the PBR calipers from 89 ( which i have) are supposed to be the same bolt pattern as the later ( 90's) aluminum calipers.....at some point i'll find out for sure....if they don't fit, then i'll just buy a set of 4th gen rear brakes...
Re: 12 bolt brakes
Check post #21 and #22 for pics of the two and their bolt patterns:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Engine: 4++,350 & 305 CIs
Re: 12 bolt brakes
the brakes from 89-97 are mostly the same.
the 9bolt rear in 89 has a diff bracket bolt pattern than the 10bolts do 4the bracket to mount the caliper.
All you need are 2 newer brackets. Or get a drill and redrill some holes on your 9bolt bracket, which is what I did.
Re: 12 bolt brakes
Both plates are available after market:
http://andyz28.com/3rdGen/reardisc.html
http://www.hawksthirdgenparts.com/brakecalipers.aspx
Check this site for more info: http://www.flynbye.com/index.html
Since I'm **** in such matters, I'd prefer purchasing the correct plates rather than modifying something to fit. But each to his own.
JamesC
JamesC
Re: 12 bolt brakes
Im kindo the same way but some of the brakets Ive seen over the yrs have a few diff hole patterns to help reduce part#s and inventory.
Engine: Lt1 in IROC
Re: 12 bolt brakes
[QUOTE=JamesC;5023899]Both plates are available after market:
hey those are great links! that's what i love about this site! thanks
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
