4th gen 6 piston wilwood front brakes
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Will the 4th gen wilwood 6 piston brakes fit on a thirdgen? i saw wilwood carries a 6 piston kit with 13" rotors and that would be perfect for my car, do you have to have any custom brackets or does it just bolt right up. Already have the wilwood 4 piston brakes up front with a 10.75 rotor and the car stops ok, just want to make it way better.
Car: 87' IROC
Re: 4th gen 6 piston wilwood front brakes
Wilwood sells a few different 13" class kits for the fourth gen. Can you provide a part number on the kit you are looking at?
If you want to use a fourth gen kit you will need to first install 4th gen brackets on your spindles. Instead I would suggest starting with a C5/C6 based kit if you want to go direct from Wilwood. The bracketry is a superior design for a swap on our cars. You would then need a C5/C6 adapter bracket installed on your spindles.
What do you plan to use the car for?
Also, what wheels are you using?
John
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
The kit you currently have probably has the Dynalite calipers which are just terrible. They are really designed for low horsepower, 2000lb cars. They have no business on our cars other than a straight drag kit.
John
John
I am open to using other brakes like the c6 zo6 brakes or any other brand out there, trying to keep a reasonable price on brakes. My car is a street strip car. My car is pushing quite a bit of power the tuner i have is thinking around 700rwhp+ . Right now I have zo6 c5 rims 17" in front and 18" in the back. I really need something better than the brakes i have right now, they work ok,but not much better than stock. i have 12 bolt strange with 4th gen ls1 brakes in the back and the rotors are bigger than the front looks very awkward on my car.
Car: 87' IROC
Thanks for your response, I was looking at this kit http://www.jegs.com/i/Wilwood/950/140-9833-D/10002/-1
There are a lot of great options that fit 17" wheels and will perform well.
Wilwood FSL
Wilwood W6A
C5/C6
C6 Z06 (fits some 17's, not sure about yours)
Camaro SS (fits some 17's, not sure about yours)
I took a look at the C5/C6 based kits on the Wilwood website and it looks like they all use the Narrow caliper as well.
John
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
There was a 6 piston, 13" rotor wilwood custom brake setup that Vetruck made years ago on his 92. That was a lightweight setup and he used it for track racing.. It also fit inside the 16" IROC wheels.
Car: 87' IROC
With that said, we already have the Wilwood FSL 4piston 13" kit that fits inside of the IROC wheels. Using the six piston version of this caliper would fit no different, just cost a little more. This is a pretty potent kit for a reasonable price.
John
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
after doing some more research i think i am going to get the 13" FSL kit from flynbye 4 piston brakes 1 piece rotor and cross drilled slotted brakes.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Wilwood makes a number of six piston calipers that are directly interchangeable with their 4 piston models. Even the pads are interchangeable. The only real advantage of the 6 piston models is they have differential piston bores to reduce pad taper. Granted they are getting better at doing this with the 4 piston models as well. So at the end of the day, using their 6 piston calipers is not much of an upgrade over the 4 piston models but costs more of course.
John
John
Car: 87' IROC
There are other part numbers for different piston sizes, but that is the size I would use.
Regarding brackets. I use my own design. I made a number of sets and actually have some left over. There is some more info here:
https://www.thirdgen.org/forums/brak...ake-kit-3.html
Car: 87' IROC
The benefits of this brake package over the 1LE package definitely outweigh the extra few lbs IMO.. I would get aluminum hubs to offset the extra added rotational weight of the rotor.
Car: 87' IROC
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
6 piston caliper ? Really ?
The parachute board might be more useful to you.
What are we trying to stop........the space shuttle ?
I mean....really
I mean....really
Car: 87' IROC
The number of pistons really does not have much to do with it. Its mostly the piston area that matters. There are some key advantages to 4-6 piston calipers , but I'll save that discussion for another time.
The OEM front brakes on these cars are awful. If you are going to upgrade, might as well do it right. The setup 90-irocdx3 is talking about is not an overkill setup. It would be great on the street and on a road course.
John
Car: 87' IROC
I don't have 1LE stuff in front of me, but based on the weights listed on Autozone, it seem like the 1LE setup should be a little heavier than that.
Rotor: 25.75
Caliper: 7
Pads: 2
Bracket: 1
Total = 35.75lbs
That leaves only 4lbs for the spindle, bearings, seal, spindle nut/washer.
Those things combined should be in the neighborhood of 10lbs. Is the weight you listed actually what you personally have measured?
I'm just curious, like I said I don't have 1LE stuff in front of me. The component weights I have listed seem pretty reasonable.
Now, I also don't have the total weight handy for the Wilwoods, I can weight them maybe this weekend. Either way if we look at the component weights, this is using the FSL 4 piston caliper and a C4HD rotor with an aluminum hub.
I have the Wilwood kit being about 2lbs lighter than the 1LE. I am surprised.
Rotor: 20.25
Caliper: 5.25
Pads: 2.5
Hub: 4.5
Bracket: 1
Total: 33.5
John
Jet,
John
John
OEM brakes are awful but 6 piston calipers on a street car is totally and completely overkill and like one of those elite, totally top of the line, money doesn't matter write ups in car magazines we all complain about.
Least use some common sense, this is not main stream, this is about as useless to the average 3rd gen owner as the thread we have on putting ABS on these cars.
Come on guys...at least your thread would actually stop the car quicker and likely not create a bunch of issues in the process but your mod is a massive over reach.
Whatever works for the one guy that might be silly enough to do this. This is ridiculous.
Car: 87' IROC
You have to remember a few things. I notice you car has only 9k miles. For this reason I suspect it is a garage queen and not driven hard on the occasions when it is driven. For you, originally is probably a large factor.
What you seem to ignore is that many of us road race, track our cars. Our thermal demands are much greater than yours. I can assure you a mid sized Wilwood caliper on a 13x1.1 rotor is by no means overkill. In face it is quite right sized for our big heavy cars. Remember just because it has 6 pistons doesn't mean it is a large caliper or provides to much force. It all comes down to hydraulic advantage. Did you know, all of the calipers we are talking about here have a SMALLER piston area than the stock calipers?
John
Car: 87' IROC
Im Vetruck
The setup I built was 36 lbs each side complete with spindles and brake lines attached. They were 6 piston radial mount calipers and 2 pc 13" rotors with custom made aluminum G-body (yes I said G-body) hubs made by Global West for a 4000lb G-body racecar. They still had a CAD file and made me a dupicate set that matched with the same offset and Timken bearing sets that we have on F-bodies.
Why 6 piston?
If you do research and understand pressures, the 6pot caliper has less overall piston volume than the same 4pot caliper in that spectrum. The 2 extra pistons allow for a better force distribution on the back side of the pads for a smoother and more even applied pressure. The caliper gave me less pedal travel and mated better in volume 'in proportion" to the smaller Wilwood Dynalite 4 piston caliper I used in the rear (12.2" 2pc rotor).
It boils down to calculations and MC chamber bore volume, etc.
Dean (aka Vetruck)
Why 6 piston?
Dean (aka Vetruck)
I assume you measured those weights yourself? Do you happen to have the weight of the rotor handy? Was it a 1.25" thick rotor?
You point about about the six piston calipers is quite true for Wilwood. In general they have been behind the trend of using differential bore calipers. So to get the differential bores, you needed to use their 6 six pistons calipers. They are however getting better at offering differential bores in their 4 piston calipers. I think it comes down to money. Their four piston versions typically are now unidirectional so they lack the differential bores, cross-over tubes, ect... They also have the lower cost anodized finish.
Wilwood also has a tendency to use larger piston areas in their 4 piston calipers than their 6 piston. Of course that can be good or bad depending on the rest of the system and the pedal travel and feel that the driver likes.
Here is my chart comparing a bunch of common brake swaps. It is important to pay attention to the last two columns for determining what kind of brake pedal feel the driver will have.
right click - view image for a larger version
Car: 87' IROC
ps- you will not find a lighter weight setup that pound for pound has more stopping power.
Also most people are using heavier Vette products as well as putting heavier and wider wheels and tires ont he car- this is the worst thing you can do for ride quality and handling. Keep the unsprung weight light is critical for an ultimate handling car- its why things cost big $$$$ because of exotic lightweight metals.
Best car I have raced to date and have absolutely fell in love with is a 2011 Ferrari 599 Fiorano with massive 19" carbon rotors- ohhhhhh (excuse me while I lick my lips) talk about the ungodly world of Ferrari computer braking technology- you have not idea until you drive one hard- and Ive raced alot of exotic things in my day.
Just for the sake of friendly competition.
I have designed a ZR1 based carbon ceramic kit for our cars.
15.5" rotor
6 piston calipers
It is right around 35lbs installed on the spindle. Quite impressive. But it is a bit steep at over $4k just for the fronts.
Of course it also requires 19" wheels.
But yes I completely agree it is quite hard to beat the Wilwood Superlite calipers for performance to cost and performance to weight.
Car: 87' IROC
Car: 87' IROC
John,
On my link page to that car, I see that I weighed the front Wilwood rotor next to a worn out crossdrilled Stillen rear rotor in OEM size for our cars that came off my old car. The link says I wrote that the new pc front rotor was 0.6 lbs heavier than the "equivilant no hub" factory size rear rotor that was turned down and worn out (lighter than when it was new- and remember it was drilled also which reduces a little weight over a stock OEM rotor)
Jet,
John
John
Assume, assume...you know what they say. I have had four third gens. Currently have two.
Really this conversation has nothing to do with a particular model...............this is about extreme overkill for a street driven vehicle................
50 years old, aircraft mechanic and loads of common sense and logic.
This is simply not needed..............you guys are road racing.
Fine have at it but this is ridiculous to anyone with an average street vehicle and you know it.
Smaller piston area but larger pad surface area.......I got it.
Still way more than anyone of the 99.9% here needs and any c4, c5 or ls1 or that size would be more than adequate and substancially reduce the stopping distance.
AS said I could put a parachute out back but is it necessary ?
Car: 87' IROC
Second of all, I didn't realize we were talking about average street cars. When did that happen? Clearly we are talking about people who want more from their vehicles.
Finally, have you looked at the prices? You can put together a nice Wilwood kit for the same price as new C5 stuff.
I don't really want to start an argument. I suspect if I told you what I do for a living you would have even less respect for what I say. In my experience, aircraft mechanics don't think much about people who do what I do for a living.
All I will say is for what reason are you saying these are overkill? At least back up your opinion with reasons why.
My reasons:
Wilwood vs C5
both are same cost
Wilwood is simpler, less moving parts
Wilwood has larger pads, last longer
Wilwood is slightly lighter
Wilwood pads are much easier to change
both have similar wheel clearance
Wilwood pads are harder to get (most likely only online)
Finally, and I think maybe most importantly, think about pedal FEEL. To me this is incredibly important. Aside from the poor performance, the stock brakes also feel bad due to the small rotor and the large piston. What you get is a long soft pedal. I much prefer a shorter pedal.
Jet, I really hate to clog up 90-irocdx3's thread. I am however very happy to discuss the pluses and minuses of different brake setups. Maybe you can create another thread and I will be happy to post in there. Out of respect for 90-irocdx3 I will not continue this discussion here unless it is on topic.
Thanks,
John
Last edited by 87350IROC; Jan 8, 2013 at 01:56 PM. Reason: suggest new thread added
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Im Vetruck
Why 6 piston?
My brakes ran enough heat no problem for daily street use and would stop the car in an incredible 102 feet from 60-0. A stock 87 IROC did the same stop test in 147 feet. That is 45 feet shorter or almost 3 car lengths. So again why? for safety if in a panic situation on the road, I would stop and the IROC next o me would plow into at least two to three cars in front of him causing an accident given the same panic condition.
Did I also mention this test was done on 220 tw DOT street tires that were factory size 245/50-16's on factory 16" x 8" wide IROC wheels?---yes.
http://www.cardomain.com/ride/518752...-6/#5187520072
Dean (aka Vetruck)
Why 6 piston?
Dean (aka Vetruck)
As John mentioned in another post, I bought one of his 4 piston Wilwood FSL kits for my GTA. While it hasn't been installed yet, I can easily see it used on a road race car with the change of a two piece rotor (the 1pc would warp) and possibly a more race oriented pad. A 6 piston may offer a larger pad and better clamping force, but the rotor is the real issue - it is in fact a radiator that has a finite thermal capacity. That being said, in a lot of cases, there is a sweet spot in braking performance vs. cost vs. fitment - and it is usually a smaller kit than most people feel is necessary. Most cars can't overheat a 13" rotor in a short race - if they can, brake cooling ducting would solve that problem 80% of the time.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Application has a lot to do with it. I have these: http://www.wilwood.com/Calipers/Cali...o=120-8000-FSR Website says: heavy-duty street; medium duty road race.
Three - 25 min sessions around Road America resulted in this wear of brand new BP-10 pads. Obviously, I need better pads for this track. Generating some heat! Almost scored the rotor - look at the upper left outside pad. Back side of pad pretty close wear - result of the 6 piston?
Dean:
Ferrari Club of America 50th Anniversary
http://www.roadamerica.com/Races/Rac...ion.asp?id=330
Dean:
Car: 87' IROC
Ahhhhhh, I just caught it. Your calipers are the narrow models. So your pads are a good bit smaller than the full thickness models. The narrows have 78% the volume of the 7420. So your pads will run hotter. So that helps explain some of it, but still I think you have a compound issue.
Road America is a fast track. I have used the full thickness 7420 pads with the BP-10 compound on Pacific Raceways with much less wear than yours.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Yes, narrow - less pad, but light w/2 PC rotors and alum hubs. Not overkill, just a little different approach.
Yes again, definite compound issue.
Car: 87' IROC
Agreed, just trying to think up a reason for such a drastic difference in experiences we have had with the BP-10's. I am the type who always wants to know why. I think its a combination of a few factors.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Going to do the spring mod for the rears - prop valve. I suspect that the fronts did all the work. Hawk pads on rears still look good.
If the fronts did all the work, then that is really good pad distribution by the 6.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would report Jetmeck posts as inflammatory and spam, forget EVERYTHING he says then put him on your ignore list. All the posts I have read of his (granted I haven't read them all) are negative to the point where I wonder why he even bothers to post. He tears down all ideas with no helpful reply. He was able to get one thread locked from being off track from the (non) discussion. He brings nothing to the table but brings you down to his level and beats you with experience.
Car: 87' IROC
Ah, another good point. I have been using a Wilwood adjustable prop valve for many years now.
Car: 87' IROC
Back to topic- the advantage of a 6 piston caliper is in fact the even pad wear. You can not get that with 4 piston calipers using the same pad length. I used that exact same SL-6 caliper where I could shim it to use the 13.06x1.25 GT48 curved vane rotor. That combo would handle that car on Laguna Seca for 40 laps no problem. I use to run the car on California Speedway with the lightweight SRP rotors and pull it down from the turn two bank onto the back stretch turn3-4 chicane from 125mph down to 35mph and they would be cool by the time I lapped around and came into the pits. I would eat the BMW M3's for lunch under that high speed brake zone (pic attached- note by frame 7 the nose of my car is out of the shot. the M3 had to brake much earlier than me. I would gain about 4 car lengths on him in this corner entry alone. He was about the same curb weight and wider tires)
Paul, I have run against in sutox as well as have driven on several cars with Baer track brakes on their 3rd gens. One of them happens to be the kid I mentor on here (Black Mamba, or Valentin) My car would eat the crap out of his brake setup and I know Valentin will not take offense to that statement becasue it takes nothing away from how well his car performs. Hands down he would never pull the stops I did, I have driven his car on tracks and the street countless times to know this first hand.
The 7420 and 7416 pads used in the SL family were designed for 4 piston calipers. They were created in the days before 6 piston calipers were common. As a result, there is excellent coverage on the pad by the pistons. The 6 piston is fine as well. Long thin pads like the C5 / 4th gen would be better suited to a 6 piston caliper, but are stuck with the 2 piston calipers.
Here is a picture of the piston coverage of the FSL 1.75"/1.75" caliper on the 7420 pad.
red90IROCls1
Aug 25, 2015 06:56 AM
