Goodridge G-stop brake line question.
Old Jan 31, 2013 | 03:48 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Looking to replace the stock lines with quality parts. I currently will be running stock sized calipers and rotors/pads.
I went to Stillens and came upon these...
http://www.stillen.com/product/brake...252-38323.html
Its a model 12252 for the 1984-1988 firebird/camaro
Then I went to Tire Rack and saw these...
http://www.tirerack.com/brakes/brake...4&autoModClar=
Its a model 12253 and it came up during my search....
but it comes up as a "Performance Brakes" option...What the heck does that mean?
From what I know, there were no 1LE or Special Performance disc brakes as an option during the 1984 model year..
Called the rep at Tire Rack and he doesn't know the difference, called the rep at Stillens and he wasn't sure but had a "hunch" that its the 12252 (w/out performance brakes option)
So my question(s) are:
1) Were there any "Special Performance" brake options for 1984 F-body's?
2) Which part # should I get 12252 or 12253?
Help!
Chuck
Old Jan 31, 2013 | 04:31 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: Goodridge G-stop brake line question.
How many rubber lines do you have? Thats the question. I have 5. 2 in front 2 for each rear caliper and on off the main line to the rear that is the splitter. Performance brakes may mean 4 wheel disc. There come in either 3 or 5 line kits. I habe the goodridge kit , better than any kit out there. If your still stumped call goodridge, they have a tech line.
Old Jan 31, 2013 | 05:00 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I think the performance brake option actually mean 1LE, which uses different fittings.
I bought the Goodridge stainless brake line kit for my 1988 IROC with rear disks and it has two hoses for the front and three for the rear.
The quality is great and I love them.
Old Jan 31, 2013 | 07:05 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
How did you like the fact goodridge still sells that kit with the wrong pitch banjo bolts for the aussie pbr calipers. Called and they sent out the correct ones. On an 84 if you have drums you will need the three hose kit.
Old Jan 31, 2013 | 07:15 PM
peterc005's Avatar
Transmission: T700
Mine fitted perfectly. You just need to be careful and specify the correct model.
Old Jan 31, 2013 | 09:04 PM
Chuck84TA's Avatar
I have 4 wheel disc brakes and I know for absolute certainty that they are not 1LE unfortunately....
Did the Camaro have a special braking performance package from 1984 to 1989? I thought the 1LE's didnt come out until 1989
Old Jan 31, 2013 | 09:57 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The 1LE package came out in 1988. Only 4 Camaros came with it. Not many Firebirds had it either.
I tried looking up 1988 brake lines on Stillen's site. The result being regular 4 disc cars are #12252. While the 1LE cars are #12253...........My car ('89 with regular 4 disc setup) is a #12254. (different rear brakes compared to the 1988 model)
The trick is to look at the what years each fits what on the Stillen site and remember it's an "and/or" deal when dealing with the 1LE option.
#12253 = 1985-1988 cars with performance braking package....But the performance braking package is only on the 1LE cars, which only started in 1988. This is no good for you.
#12252 = 1984-1988 cars without performance braking package. So every car with 4 discs without 1LE (essentially all of them except for the 4 Camaros in '88). This is the one you want.
Old Feb 1, 2013 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I think auto parts stores have contributed to the confusion. All 82-92 cars with four wheel discs, regardless of the type (standard or 1LE/PBR), are RPO J65. Purchasing decisions are made more difficult because of the 'performance or 1LE designation,' which as Reid points out, is only for the 88/89-92 cars (alum PBR calipers and 11.7" rotors). Standard J65 brakes (iron Delco-Moraine calipers with 10.5" rotors) came on 82 to nearly all 88 cars.
JamesC
Old Feb 1, 2013 | 11:30 AM
Chuck84TA's Avatar
Looks like Im going to go with the 12252's, Thanks Guys!
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
