Whats the best way to remove a Proportion valve?
Old May 21, 2013 | 03:56 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I really want to get this thing out to properly clean it up and get it working correctly, I have tried the hammer/tap test, it's no go, already replaced the master cylinder, but I only get periodic pressure for a minute or two , then it let's off!
I already called around and non of the auto where house's sell it anymore, which means having to order one via GM or Summit racing.
any advice will be greatly appreciated*
Old May 21, 2013 | 09:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Whats the best way to remove a Proportion valve?
You can replace the spring inside the prop valve with a grainger spring. Many members have done it with great results.
Old May 22, 2013 | 07:50 PM
sheltonw3's Avatar
Engine: Classified
While it's still in the engine bay?
Old May 22, 2013 | 07:51 PM
sheltonw3's Avatar
Engine: Classified
Well, I have to see what is next and if I cannot find that part, I might just order a new one from Summit*
Old May 24, 2013 | 07:10 PM
sheltonw3's Avatar
Engine: Classified
Where can I order one from?...is there part # ?
Old May 26, 2013 | 12:16 AM
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
Try calling Grainger. They may know just what specific spring you need. Here is a link: http://www.grainger.com/Grainger/ecatalog/N-/Ntt-spring
Old May 26, 2013 | 01:32 AM
kauboy's Avatar
Car: 83 Z28 Crossfire
https://www.thirdgen.org/forums/brak...e-upgrade.html
Old May 26, 2013 | 10:05 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
How to remove it?
Unscrew the lines and remove it.
Replace the spring, put it back in and bleed the system.
Old May 30, 2013 | 04:10 AM
sheltonw3's Avatar
Engine: Classified
Originally Posted by Johnny Blaze
How to remove it?
I tried all that , the bottom bolts will not give and I am afraid of tearing a line or two, so I will look into replacing the forward spring and have the brakes bled all the way around for good measure
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
NBrehm
Aug 25, 2015 11:49 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
3rdgenparts
Aug 8, 2015 07:09 PM
