Brembo ctsv/ss front caliper lines
Old Oct 23, 2013 | 09:51 PM
TeeBee8125's Avatar
What are you guys using for front brake line... I have ctsv front calipers
Old Oct 24, 2013 | 12:48 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Brembo ctsv/ss front caliper lines
Send 87350IROC a PM, he should be able to make you a nice custom set at a price lower than most stainless aftermarket pieces.
Old Oct 25, 2013 | 02:18 AM
87350IROC's Avatar
Car: 87' IROC
You would need a custom line to maintain all the factory guides. The line needs a 90 degree banjo fitting, strut bracket guide, body line fitting with body bracket clip groove.
Old Nov 9, 2013 | 04:45 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
bought mine from scott at bigbrakeupgrade.com perfect fit with the right angle for mine.
Old Nov 17, 2013 | 10:31 AM
Pocket's Avatar
Car: 91 Trans Am
I used OEM 1LE lines. Custom parts that are replaced on a schedule do not appeal to me
Old Nov 17, 2013 | 10:56 AM
TeeBee8125's Avatar
Pocket that's what I mean too if any of this guys just stop making these parts I am out of luck.... What's did u do to get the 1LE lines to work ... I was thinking about trying to use the ss camaro or ctsv stock lines or maybe ls1 type line
Old Nov 17, 2013 | 11:03 AM
87350IROC's Avatar
Car: 87' IROC
Not really. Go to your local Brakequip dealer and have them made while you wait. Takes about 20mins. It will probably take no longer than going to autozone and buying replacement 1LE lines, if they even have them.
Also, I don't believe OEM 1LE hoses have a 90 degree on the caliper side? If I am right, now you have a bend point right where the hose goes into the fitting. Not something I would do.
Pocket, do you have a pic of the installation?
Old Dec 5, 2013 | 05:22 PM
Pocket's Avatar
Car: 91 Trans Am
Only pic I have at the moment
Mine use a custom bracket for the 13.5" rotor to fit under 17" wheels, so the generic LS1 bracket may be different. I do recall the 1LE lines being strait which isnt perfect but livable. I had to cut off the steering stock brackets from the A-arms to prevent pinching them at full lock. The steering box internal stops prevent the lines from being pinched at full lock now, not that I ride at full lock. One other thing, the strut mount clip didnt reach, so I had to zip tie it on
In hind sight, any long hose with 90* ends would be superior. If you've got access to a custom line shop, use it. I did not, and did not want to pay 10x the cost from an online store when rock auto had the stock stuff so cheap
Old Dec 7, 2013 | 06:31 PM
87350IROC's Avatar
Car: 87' IROC
NO custom line shops in the home of NASCAR????? Just kidding.
Old Dec 16, 2013 | 07:13 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
here is my current set up
Attached Thumbnails Brembo ctsv/ss front caliper lines-imag0608.jpg
Old Dec 16, 2013 | 07:45 PM
TeeBee8125's Avatar
What lines are u using tho
Old Dec 16, 2013 | 08:08 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Earls Speed braided stainless steel and I think they are 20" long cause the on the CTS-V are mounted to the bottom side of the calipers
Old Dec 17, 2013 | 03:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
^ Same here, actually, they are still in the mail, but thats where they are coming from
Old Dec 17, 2013 | 06:54 AM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Very nice Scott is a personal friend of mine, on his website the cts-v set pictured is the first set he every did, and currently on my car, he is a great guy, does great work too.
Old Dec 20, 2013 | 09:44 AM
TeeBee8125's Avatar
Finally made some head way on these lines thanks to the info from John I went to colliflower a local hydraulic hose company brought them my old parts and my new parts and we found all the correct fitting to get lines made in less then 15mins pressure tested and all.... Name:  null_zps3c082b2c.jpg
Old Dec 20, 2013 | 12:19 PM
87350IROC's Avatar
Car: 87' IROC
Hoses look great. I will get back to you on the rear info in a few days. I am traveling.
John
Old Dec 20, 2013 | 04:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Told ya he could help you. I bought my Wilwood FSL kit from him. Great guy.
Old Dec 20, 2013 | 06:59 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
its up side down though
Old Dec 31, 2013 | 06:54 PM
TeeBee8125's Avatar
Just got my rotors back from machine shop
Old Jan 1, 2014 | 09:13 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
[QUOTE=Pocket;5677129]Only pic I have at the moment
Mine use a custom bracket for the 13.5" rotor to fit under 17" wheels,"
- Can you post some of the specs of your set up, on how you got a 13.5 rotor to work on the 17" wheels, also how does it work??
TeeBee8125
Same question, also what wheels are the 5 spokes with the lip? those look awesome.. What kind of car is it going on (Z,Iroc,GTA,etc..)
Old Jan 4, 2014 | 09:57 PM
TeeBee8125's Avatar
The wheel are BMW offset
Old Jan 5, 2014 | 10:21 AM
Pocket's Avatar
Car: 91 Trans Am
Same basics of any brake upgrade. Same bracket Ive posted several times
Use C6 Z51 rotors, CTS-V calipers, that bracket and mod the hubs/spindles like any other upgrade
Old Jan 18, 2014 | 11:14 PM
TeeBee8125's Avatar
Size:  88.1 KB front and rears are complete now
Old Jan 30, 2014 | 09:26 PM
TeeBee8125's Avatar
All done now
Front bracket from big brake upgrade.com
Rear are from flynbye( Ed miller)
Brake line from local hydraulic hose shop
Caliper from eBay ctsv front ss rear
Rims are 19 all around
Motor is a procharged ls swap 6.0
Now I going start digging in the suspension set up
Old Jan 31, 2014 | 06:45 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Scott from BIGBRAKEUPGRADE.COM will have the rears very very soon, so keep an eye for them
Old Jan 31, 2014 | 07:39 PM
87350IROC's Avatar
Car: 87' IROC
Car looks great.
Am I imagining things or is the caliper not straight. The gaps (top and bottom) between the inside edge of the rotor friction surface and pad edge don't look consistent. The top gap looks much larger than the bottom gap. It may just be a shadow. But the bottom gap looks correct. It should be about 1/4".
1992rs/ss
Jan 31, 2025 05:10 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
