My car is pulling when I apply the brakes
Old Feb 13, 2014 | 10:17 PM
barlowjohn2081's Avatar
Car: 1987 Camaro sport
Engine: V6 2.8L
Axle/Gears: Stock
I just put new brake shoes on but hen I apply the brakes, it will pull to the right and then even back out by pulling slightly to the left. I'm not sure what is causing this.
Old Feb 14, 2014 | 04:54 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: My car is pulling when I apply the brakes
You probably have a sticking driver side caliper. The car will pull to the left because it is always slightly dragging. When you hit the brakes, the right caliper works so it grabs more and pulls you that way.
Jack up the front and spin the wheels, you probably will notice more drag on the left one than on the right one.
Old Feb 14, 2014 | 06:17 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
You could also have a stuck caliper bracket pin that won't allow the brakes on the right side to fully engage. This happened to my wife's car not too long ago. When I took the brakes apart, the pads on the stuck side were only half as worn as the other side. A stuck caliper would also make that particular wheel really hot after driving a while. Oil or brake fluid on the brake linings can also cause this.
Old Feb 14, 2014 | 06:47 AM
More likely, the rubber hose is all rusted up inside, and is blocked.
Change all 3 of em... all 3 are made of the same material, with the same size pinhole in them to begin with, have been on the same car, with the same moisture-filled fluid in em, for the same number of years, months, days, hours, & seconds; and are therefore most likely all in pretty much the same state. Renew ALL the brake fluid. MAKE SURE you don't let the master cyl run dry EVER while you're doing this, i.e. MAKE SURE you keep the reservoirs full of fluid.
Old Feb 25, 2014 | 09:37 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
That's it. As a long term owner of the same third-gen (24 years), whenever this happened, it turned out to be the rubber brake lines. Now I have braided steel lines and I change the brake fluid regularly so that it is never a problem.
However the stockers will last about seven years and then degrade inside the brake line. It's your lines.
Old Mar 24, 2014 | 07:34 PM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
It could also be a dead caliper, if new fluids and lines don't fix it.
Old Mar 24, 2014 | 08:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
+3 for the lines.
JamesC
Old Mar 25, 2014 | 11:30 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
make that +4 for the lines, had an issue where my car would pull hard right under moderate braking, changed calipers and pads, still did it.
changed rubber lines, problem gone
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
