help with my brakes
Old May 14, 2014 | 10:07 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
help with my brakes
a little back story...
my car was sitting for four years. i have been going through everything getting it all going again. right now i am concentrating on my brakes. as of right now it takes a lot of effort on the brake pedal to full stop. when i first hit the brakes they grab pretty good. but at slow speeds coming to a stop i have to press the pedal hard to completely stop the car. only thing i have done so far is completely flush and bleed the brake fluid.
i have heard that you can test the power booster by having the engine off pump the brakes till they are hard then hold pressure on the pedal and see if it holds. mine does hold. so my power booster should be good right?
my next idea is to replace the front rotors and pads. could it be anything else i havent thought of yet?
Old May 14, 2014 | 10:24 PM
Re: help with my brakes
one more thing. i was driving around and wanted to see how good the work or not. i was going about 20mph and slammed on the brakes as hard as i could. i couldnt lock up the tires. my car is non abs. idk if that helps or not.
Old May 15, 2014 | 11:23 AM
Bump
Old May 15, 2014 | 08:24 PM
no one has any ideas?
Old May 15, 2014 | 08:29 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
how much vacuum are you pulling, in gear at a idle. You need 13- 15in for the booster to operate
Old May 16, 2014 | 05:21 AM
You know what, I haven't checked vacuum in gear. But in idle at 900 rpm I have 14-15. In gear idle drops to 600. I will check it today.
Old May 16, 2014 | 07:01 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
The brakes on these cars suck, that's why there's so many brake upgrade threads
Old May 16, 2014 | 08:50 AM
Joe Tag's Avatar
Still have the original rubber lines on it? If so, I'd replace them, fairly cheap and easy to do. Needed or not. They are notorious for collapsing.
Old May 16, 2014 | 11:32 AM
Yeah, I ordered new ones. And new rotors and pads
Old May 16, 2014 | 03:44 PM
OK so in neutral at 900 rpm it is 14-15
In drive at 600-650 rpm it is 11-12.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
