Parking Cables on rear PBR converion
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Hoping JamesC is reading this, I know he's got the same setup. I'm finally finishing up this rear PBR conversion on my '85. I have the 1434mm cables, but when I installed the driver side the the parking cable is very taught like its not routed correctly. Does anyone have a picture illustrating the routing?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Parking Cables on rear PBR converion
Maybe some help below.
JamesC
JamesC
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
It doesn't show the PBR set up but if you copy the left side it should work. I also thought the standard routing put tight bends in the cables so I've changed mine to run under the axle. They are loosely wired to the sway bar to stop them sagging. Seems like a more natural routing for the cables.
Both mine are routed over the axle (as on the driver's side). No issues with the 1434 cable.
JamesC
JamesC
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I didn't really have any issues I just didn't like the tight bend with the over axle routing and I noticed the cables I have are quite worn where they go over the axle.
Car: 1985 Z28
I used guides.
ambainb
Apr 25, 2016 09:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
