So this happened...
Old Jun 20, 2015 | 08:17 AM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
So this happened...
Rear Driver brake was leaking brake fluid... popped it off and....
here's the passenger side for reference...
Does it look like an axle seal popped too? Or just the brake fluid attracted a bunch of crap?
The puddle underneath the drum evaporated so I know its brake fluid... but the amount of crap in the drum concerns me.
Any thoughts before I go spend money on a new cylinder or two?
Old Jun 20, 2015 | 08:32 AM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: So this happened...
I would say you seal is leaking also. Replace the seal, clean up the drum, and replace the shoes.
Old Jun 20, 2015 | 08:49 AM
tyeo098's Avatar
Car: 88 Chimera
Yeah.
It appears I'm going to need a new cylinder regardless.
Should I do all the seals while I'm at it?
Old Jun 20, 2015 | 09:41 AM
Stauf's Avatar
Car: 91 Z28 Coupe
Originally Posted by tyeo098
Yeah.
If it was me, I would replace everything that I could. You already have the drums open, and why would you want to do this again in 6 months?
Old Jun 20, 2015 | 01:33 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If it was my car it would all get replaced since the cost of most of the parts is low.
Old Jun 20, 2015 | 01:36 PM
tyeo098's Avatar
Car: 88 Chimera
Replacing everything but apparently there are metric and US threaded cylinders.
Guess which one I bought!
Old Jun 20, 2015 | 06:45 PM
tyeo098's Avatar
Car: 88 Chimera
Trip to the other advanced...
All fixed and bled. Leaky oil gasket replaced.
Thanks guys!
Old Jun 21, 2015 | 12:50 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
that new axle seal won't do much good if the bearing wore a groove in the axle and it has too much free play.
hale89
Nov 16, 2012 06:02 AM
pvr007
Apr 26, 2012 01:54 PM
whiteroc
Apr 5, 2002 01:08 PM
