Hatted rotors for stock 1LE brakes
Old 06-14-2018, 11:42 PM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
does anybody make a 2 piece or hatted style rotor for the stock 1LE brakes? The brakes on my 1LE are plenty for what I do with the car, but I am ready for rotors and pads and I was looking for some high end rotors to put on the car if there were anything. I didn't see any through the usual manufactures
Old 06-15-2018, 12:19 AM
COTM Editor
QwkTrip's Avatar
Received 1,855 Likes on 1,270 Posts
Car: '89 Firebird
Engine: 7.0L
Re: Hatred rotors for stock 1LE brakes
Maybe call Kore3. You never know what those guys will come up with.
Old 06-19-2018, 08:00 PM
LC2 TECH's Avatar
Not that I am aware of. BAER makes a nice drilled and slotted replacement rotor.
Old 06-20-2018, 11:50 PM
Car: 1992 Z28 1LE
I tried them, and was told they quit making them a few years ago
Car: 1992 Z28 1LE
Ideally I would like something with a hub with a slide on hat and removable rotor from there
Old 06-21-2018, 08:58 AM
Beater79TA's Avatar
You could try piecing something together. You would need to know rotor thickness and the rotor centerline relative to the hub face. Then check the aftermarket catalogs to see if anyone makes a rotor and hat combination that is the correct diameter and thickness on the rotor and the right offset on the hat to get the centerline and thickness correct.
You can buy hubs at bigbrakeupgrade.com as a starting point for the hat measurements.
Expect to spend 4 or 5 times what a stock rotor replacement would cost though. Factory front rotor can be found for about $50 each. By the time you do hubs, hats, and rotors you're probably looking at close to $500 per side with replacement rotors going for $150 or more each when they need to be replaced.
Old 06-22-2018, 08:17 PM
LC2 TECH's Avatar
Are you talking about the stock replacement ones or something else.
Old 06-22-2018, 11:29 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
I think he's talking about a multi-piece brake rotor, but without modifying the stock spindle.
ebmiller88
Brakes
03-11-2006 07:34 PM
crazyjoe
02-28-2003 01:37 PM
breathment
02-05-2002 10:50 AM
THREAT
Theoretical and Street Racing
102
10-26-2001 12:55 AM
1992 B4C 1LE
02-03-2001 12:05 AM
Quick Reply: Hatted rotors for stock 1LE brakes
