What the Balls? need help(non 3rd gen though)
Old Sep 8, 2002 | 05:52 PM
85NJTA's Avatar
What the *****? need help(non 3rd gen though)
Hey, ok here's the problem...in my s-10 xtreme i have two 10 in soundstorm labs 600w max subs powered by a soundstrorm labs 1000w max amp. the problem now is that the sub behind the driver seat is not playing/hitting as loud/hard as it should..it sounds muffled compared to the other... i took out the head unit, checked all connections at unit and amp, checked all wires from amp to subs and tried adjusting levels...what am i doing wrong or what may be wrong??..i am gonna stop at the sound shop tommarrow on my way home but any suggesions.:hail:
Old Sep 8, 2002 | 09:13 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Pull that sub outta the box. I bet there's a little smoke that's gonna come with it. If so, then you smoked it.
You don't have to take it out to tell though. Just turn the system off, go to the good sub and push it down a little with your fingers. Push down equally on opposite sides of the sub so it goes staight in, and don't push hard. Take a mental note of how it felt and how easy it was to push.
Now go to the other sub. If it's harder to push in and/or makes a scraping noise when it goes in or out, then you blew it. It's done, put a fork in it and get another.
AJ
Old Sep 8, 2002 | 09:29 PM
85NJTA's Avatar
allright thanx, i'll do that....no smoke though when i took it out today..lol..well, this sux..
Old Sep 9, 2002 | 02:19 PM
85NJTA's Avatar
Thanx for the help, but i figured it out, actually dad helped me figure it out... luckily i had the kenwood head unit i initially had in the truck in my trans am, and a newer kenwood in the truck...so both have the same harness plug so i put the old unit in and wouldnt you know it it works fine...so i am guessing the rca outs on the newer radio are bad....:hail:
Old Sep 9, 2002 | 04:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Soundstorm? You mean soundStream?
Old Sep 9, 2002 | 07:39 PM
85NJTA's Avatar
naw, soundstorm labs...they are on the cheaper range but really good bang for the buck...http://www.soundstormlabs.com should be thier site..i like em
Old Oct 3, 2002 | 08:02 PM
85NJTA's Avatar
ok, man i suck...head unit was fine, it turns out the problem is cuz i never upgraded the wires when i moved up to the more powerfull amp and subs...wires werent the right gauge so the power wasnt getting to the subs right...
Old Oct 3, 2002 | 08:29 PM
White Ninja's Avatar
what were you running? like 18 guage?
Old Oct 3, 2002 | 09:36 PM
85NJTA's Avatar
1 was runnin like 12 or 14, i forget exactly cuz it was what i got with my original amp which was only 140watts as a gift...i upgraded to 8 gauge power and ground, 12 gauge speaker and 16 gauge remote
Old Oct 3, 2002 | 11:06 PM
CaysE's Avatar
Hey what's up... NJ here. I have a crapload of Soundstorm Labs stuff in my car (see sig). The amp I've had for about 3 years now, and I think it's starting to crap out on me. The speakers I got are a couple months old, and sound awesome with a high pass filter. If you're looking to save money for decent upgrades over stock, I highly suggest these guys. Their CD headunits aren't the best though... they tend to skip once in a while. You can find their stuff mostly on Ebay or www.huggmeister.com
Let me know how your Soundstorm System holds up.
Casey
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
