installing 6x9s
Old Sep 29, 2002 | 12:57 PM
92 z28's Avatar
installing 6x9s
hey, im going to be installing my new pioneer 6995 6x9s in my 92z. the old 6x9s i have in there were just put it, no dynamat nothing.. is there any preparations i should do before i install the 6x9s? such as dynamat around the speaker, or anything like that? let me know thanks
Dozer80464@aol.com
Old Sep 29, 2002 | 03:46 PM
BadMunky87TA's Avatar
on the metal peice that the speaker goes on to put ethier weather stripping or thicker 2 sided tape,3m works good,this helps reduce rattles
Old Sep 29, 2002 | 07:24 PM
CaysE's Avatar
I believe there's already something behind the speakers that acts as an enclosure for the 6x9s. If not, you might as well put one in yourself. It's some kind of stiff foam (could be dynamat; i've never used it before) in an open end box shape between the quarterpanel and the speaker mount frame.
I'm not sure if these are on the 92z, but my car has plastic pieces in the doorwell that will rattle with new, bassier 6x9s. When you open the driverside door, look at the rightside doorwell where the latch and lock mechanisms connect to the car. It looks something like a rectangular vent. You'll want to put some kind of deadening material around this piece as well.
Old Sep 29, 2002 | 07:34 PM
92 z28's Avatar
i know the vent in the door rattles, but when the door is closed that doesnt bother me. where do i pick up one of those open enclosures for the 6x9s?
Old Sep 29, 2002 | 07:46 PM
CaysE's Avatar
I'm really not sure... see if anyone is parting out their car and get it from them, or you try building one yourself.
Old Sep 29, 2002 | 07:53 PM
try these http://www.crutchfield.com/cgi-bin/S...c=11&s=0&g=762
Old Sep 29, 2002 | 08:04 PM
92 z28's Avatar
will they help sound out all?
Old Sep 29, 2002 | 08:23 PM
racing_dude_17's Avatar
crossover
What i did to cut the rattle was to use a high pass crossover, although i have a sub for the bass. but if you just want the mid/high frequencies thats what i would do.
Old Sep 29, 2002 | 08:47 PM
92 z28's Avatar
nah, these 6x9s are made for some good bass.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
