What Does MDF Weigh In At?
Old Nov 8, 2002 | 10:18 PM
BadBowTie's Avatar
Can anyone tell me what 3/4" MDF weighs for a given size? (i.e. 4' x 8' sheet = xxlbs.)
Old Nov 8, 2002 | 11:58 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
92 lbs
Old Nov 9, 2002 | 10:51 AM
BadBowTie's Avatar
thanks
Old Nov 10, 2002 | 10:05 PM
Project92's Avatar
92 Lbs?
Is it really that heavy? {I hope so, I thought I was just getting weaker from not working out on a regular basis}
Old Nov 11, 2002 | 01:07 AM
mcss383's Avatar
Yep, its heavy stuff.
There is some stuff called UltraLight MDF, its about a 1/3 as light, not quite as strong, and more $$$ naturally.
I'm not sure where you could find it though.....
Old Nov 11, 2002 | 10:54 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Are you sure? Is it really that heavy!? I didn't think it was that heavy when I built my box..... I have almost 2 sheets of 3/4MDF in the back of my car (box, and amp-box)... wow, fiberglass is looking a whole lot better now...
Old Nov 11, 2002 | 01:11 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
im pretty sure its close to that weight like REZN8R says. remember, that is a 4 foot by 8 foot sheet of 3/4". im sure rez works with it enough to eventually get curious himself. i know that my boxes are around a half a sheet of mdf (a little less) and weigh in at 43-44 lbs give or take. i would trust that number to be at least close.
Old Nov 11, 2002 | 07:17 PM
Project92's Avatar
Hey Rezn8r,...
Now that I think about some of the boxes I've built out of Mdf, that sounds about right...
Rezn8r, Do you know how much a sheet of High / Heavy Density Fiberboard weighs? Just curious.
Old Nov 12, 2002 | 10:07 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
The Superlite MDF is made by GoldenEdge, here is a website:
www.nelsonpine.co.nz/products/superlitemdf.htm
I found a different manufacturer that claims 105lbs per sheet for 3/4", and 131lbs for 1".
As for high density, or hardboard, I've only seen that up to 1/4" thickness so I'm not sure.
Old Nov 12, 2002 | 10:47 AM
BadBowTie's Avatar
I was talking to someone over the weekend that works with this stuff all the time... and he says that the weight of 4'X8' sheet of 3/4" can vary as much as 25LBS... He says he has averaged it out to .33oz per square inch of 3/4" MDF (1"X1"X3/4")
Old Nov 12, 2002 | 12:24 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
that puts a 4x8 sheet at about 98 lbs using alittle math if anyone was wondering.
Old Nov 12, 2002 | 07:04 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I wish they would stop putting the MDF on the TOP shelf down at the lumber yard!
fbodyfreakls1
Oct 6, 2015 06:34 PM
Ragin'87
Car Audio
Jul 2, 2001 03:03 PM
kiztope
Car Audio
Jan 15, 2001 11:29 AM
