"Stealth" box update
Subscribe
Dec 9, 2002 | 02:48 PM
Because of design conflicts I decided to move the stealth box plan to the driver side compartment. Fitting this box will require removal of the cheesy cardboard storage compartment. The good news is, most things people store thee can be held in the spare tire compartment instead. So here are a couple of pics of the new design. It will be ready to mold this week and ready for production within a month (after I get the first 2 out which are already sold). I haven't decided on a final price yet, but it will probably be $180 plus shipping. The airspace will be around .65 cu.ft. but can be modified to be smaller if necessary. The lock box cover will still function normally. It will fit up to a 10" dia. sub. I haven't measured depth yet, but it's around 6".
Reply 0
Dec 9, 2002 | 02:49 PM
and from the side...
Reply 0
Dec 10, 2002 | 08:10 AM
Wow. looks good...
Reply 0
Dec 10, 2002 | 08:29 AM
Looks nice i like the driver side idea because i put my amp on the passenger side.
Reply 0
Dec 10, 2002 | 10:11 AM
Is there any perticular reason you are only making them in 10" form? Also, is it possible for you to make them ~.88 cu.ft?
Reply 0
Dec 10, 2002 | 01:00 PM
because its a tiny assed space??
Reply 0
Dec 10, 2002 | 02:32 PM
Pretty much I can't fit a flat spot big enough to hold a 12" sub. The airspace could probably get a little bigger, but it would be harder to get in and out, and might cause some clearance issues.
Reply 0
Dec 10, 2002 | 02:47 PM
Hey Rez,What subwoofer would be good for this enclosure
Reply 0
Dec 10, 2002 | 02:56 PM
Since this install would limit you to a single 10", I would say any quality 10" sub with good power handling would be the best bet. A JL Audio 10W3V2 for example, or Eclipse Titanium, something along those lines. Of course just about anything will work as long as it doesn't require more airspace.
Reply 0
Dec 10, 2002 | 03:25 PM
I'm interested in one as well.
Do you think in the future you might try to mold one for the passenger side without the spare tire?
I'm concerned going from 2 12's to 1 10 is going to be too much of a difference. I love hard solid bass for my rock and rap disks.
-Matt
Reply 0
Dec 10, 2002 | 04:07 PM
Those of you worried about a single 10" not hitting hard enough need to quit buying cheap equipment, each of my single 10 setups is usually enough to get the "no its two 12's " arguement from people until i open the hatch. Heres what i'll be running for those curious on what to get, also had an eclipse aluminum 10, was very nice, we'll see how the boston works out.
Reply 0
Dec 10, 2002 | 04:56 PM
keep in mind theres not much mounting depth in the drivers side storage compartment..
Reply 0
Dec 10, 2002 | 06:37 PM
I probably will make one for the passenger side someday, but this one has been 3-4 months in development so far, so I wouldn't hold your breath
A single 10" can be made to sound really good and really loud. Of course if you use the same quality equipment with more than one 10" it will be louder. Personally I think one good 10" and 200-300 watts is enough for normal cruising, and this is from a guy who used to roll around with 2 15's back in the day. Technology has done wonders for car audio.
Reply 0
Dec 11, 2002 | 01:15 PM
That looks pretty good, I have my amp and crossover mounted on shelves in the smae spot. I really like the stealt systems a lot. Nice work
Reply 0
Dec 11, 2002 | 01:36 PM
i use 2 10"s...maybe after that day you make the passenger side, i'll buy one of each.
that'll make for a clean looking install with 2 stealth 10s, lots of bass and all my storage area.
- Andy
Reply 0
Dec 11, 2002 | 01:39 PM
The reason I ask is because I have an old style 12" solobaric that I use now. At the moment it fires toward the the tail lights (it used to fire at the gas tank) but I am toying with the idea to build a box so it fires up. The idea is nice but actually building a good box with a circular saw isn't that easy.
I don't really want to buy a new sub AND a box... but I could put the solo in my daily...
Reply 0
Dec 11, 2002 | 05:13 PM
Quote:
Originally posted by Kj Rockz
Wow. looks good...
Say you remind me of tripple H.
Reply 0
Dec 11, 2002 | 05:15 PM
Yeah Man thats where the box should go. I mean what do you really want to throw your spair tire out. What if you get a flat in some freezing rain or snow. Great! I think I'll keep my spare. Driver side=good idea.
Reply 0
Dec 11, 2002 | 05:37 PM
cause the tire weighs a lot and, should you need to use it, you have to inflate it with a 20-year-old can of air?
Reply 0
Dec 12, 2002 | 12:33 PM
OK. Well, I may need a driver recommendation for the enclosure's mounting depth.
Z28racer, don't worry, I don't buy cheap equipment.
I will be powering it with an old school Rockford Fosgate Punch 200x2 bridged mono. Should be 400 watts RMS into 4 ohms. Even that may be underrated with this version of the amp.
-Matt
Reply 0
Dec 12, 2002 | 12:42 PM
I used to have one of those amps. They're well respected. I ran mine down to 1 ohm for awhile, but the sound quality just wasn't there. The sub was bouncing around out of control. No damping at that load. 4 ohm works really well though. I'll look at the enclosure today and check the real mounting depth.
Reply 0
Dec 12, 2002 | 04:15 PM
REZN8R, kind of off topic, but in all of your digging around in the hatch, do you think there is anyway conceivable to make a "stealth" 12" sub box on either side of the car? I haven't taken the time to take any panels off so I don't know how much room is back there. I realize it probably wouldn't fit under the panels, but I wanted to get your opinion on the subject.
Reply 0
Dec 12, 2002 | 04:55 PM
I think you could fit one in the pass. side behind the panel. The spare would be gone though. That's probably what I'll work on next.
Reply 0
Dec 12, 2002 | 04:57 PM
Cool, thanks man. Keep us updated.
Reply 0
Hey Rez, will that Stealth box fit a Type-R 10" sub, Trying to keep as much room in the trunk of the GTA. Either that or do you offer a single 10" box the goes into the well.
Reply 0
Dec 12, 2002 | 09:51 PM
type-rs use almost 7 inches of mounting depth.. sounds like it probably wouldnt fit
Reply 0
Dec 13, 2002 | 09:56 AM
Type R 10" sub has a 5-15/16" mounting depth. I forgot to measure yesterday. I'll have to post on Monday. I have done a single 10" well box. Actually 2 different ones. One that went accross the well, the other that took up half of the well.
Reply 0
Dec 13, 2002 | 01:52 PM
oops, thats my mistake--i gave you the 12" depth thats cool then, thats a pretty popular and good-sounding sub
Reply 0
Dec 23, 2002 | 05:52 PM
So what did the depth turn out to be?
Reply 0
Dec 26, 2002 | 10:06 AM
The closest point from the mounting surface is 6" (this is in the design piece not the finished product, it could end up being 5-7/8") There's an indentation on either side to clear some obstructions in the car. If the magnet on a given sub fits between these two areas, then the mounting depth is increased to about 7-1/2"
On progress: I've spent the last few days smoothing and waxing the "plug", I should be able to create the mold sometime this week or weekend.
Reply 0
Dec 26, 2002 | 11:09 AM
when will you be taking MDF orders again?
- Andy
Reply 0
Dec 26, 2002 | 11:10 AM
Late February, early March. Whenever it starts being dry and light outside again.
Reply 0
Jan 26, 2003 | 07:55 PM
I'm very interested in this!! Please let me know when the project is for sale!!
Reply 0
Jan 27, 2003 | 01:18 AM
The first box should be shipping next Monday. I'll have more info on it by then.
Reply 0
Jan 27, 2003 | 03:00 PM
I look forward to some pics of the completed piece. Do you just leave it bare fiberglass since it gets put behind a panel or is it covered some how? Any driver recommendations yet?
Also, since it _was_ hinted at, what's the forecast look like for a 12" no-spare passenger side box? Please, please, please. I have AAA. I don't need no stinkin' spare.
Reply 0
Jan 27, 2003 | 05:58 PM
I'll probably work on that one next (pass. side). The driver's side boxes will just be painted flat black. Carpet will be a $10 add-on option. I'll know more about driver recommendations when the first finished one is done.
Reply 0
Feb 7, 2003 | 02:31 PM
I should have specs and stuff Monday or Tuesday. The first production box is finally built, it just needs a little touch-up.
Reply 0
Feb 7, 2003 | 02:38 PM
Will it hold a 8" sub??
Reply 0
Feb 7, 2003 | 02:42 PM
Anything 10" and smaller
Reply 0
Feb 11, 2003 | 01:06 AM
Rez whats new whats not whats happening with your biz?
Reply 0
Feb 11, 2003 | 08:32 AM
I'll have an official press release later today.....
Reply 0
Feb 11, 2003 | 08:55 AM
  #42
rezn8r i cant wait till you get the stealth box out for sail, im really excited and i think losts of other people are ready for one.you better have a lot of them ready for sale , i bet you'll sell 300 very quickly and i deff. want one.
Reply 0
Feb 11, 2003 | 09:16 AM
  #43
I can't wait!!! :lala:
Reply 0
Feb 11, 2003 | 01:34 PM
  #44
Here's that press release I was talking about:
https://www.thirdgen.org/techbb2/sho...51#post1140851
Reply 0
Subscribe
