Radio Loc
Old Feb 4, 2003 | 03:28 PM
1mikiemike's Avatar
Radio Loc
I HAVE A 89 GTA AND THE RADIO SAYS LOC AND IT WILL NOT WORK . WHAT DO I NEED TO MAKE IT WORK . I DO NOT WANT TO GO AFTERMARKET BECAUSE OF THE CONTROLS ON THE STEERING WHEEL . THIS CAR WAS PURCHASED 2ND HAND AND I DO NOT HAVE NO OWNERS MANUAL WITH IT . ANY IDEAS THANK YOU 1MIKIEMIKE .
Old Feb 6, 2003 | 04:30 PM
1mikiemike's Avatar
HELP
Old Feb 6, 2003 | 05:19 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Re: Radio Loc
If it's anything like the radios over here in the UK, it may have an anti-theft feature which requires you to enter a code after it has been disconnected from a constant live source, for example a flat or replaced battery. If this is the case, you should be able to take it to a GM / Pontiac dealer and get it de-coded.
Si
Old Feb 7, 2003 | 04:27 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
got info for ya
Do a search fot Delco Loc.I put up a post on how to get the radio unlocked if it is.There is a web address you can go to.If you cant find it,let me know and i'll email ya the info.
Ken
Old Feb 9, 2003 | 10:34 AM
1mikiemike's Avatar
delco loc search not working
Would you please send me the info I need to unclemdp@tampabay.rr.com for the radio loc info? Thank you Mike
Old Feb 9, 2003 | 01:37 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I had the same problem. Push the mute button on the steering wheel controls and it will unlock.
Brian
Old May 8, 2005 | 03:45 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Brian
What if you put this '89 radio which was in a car with steering wheel controls is put in a earlier model car without steering wheel controls ? Any way to unlock the radio then ? Thanks,
Bill E.
Old Jul 1, 2005 | 02:13 AM
88IROCDT's Avatar
Car: 1988 IROC Convertible
Transmission: 5 Speed
Axle/Gears: G92/3.45
Check out Ebay
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
loud91rs
Oct 5, 2015 10:05 PM
Linson
Oct 1, 2015 09:50 PM
