To amp or not to amp?
Old Apr 10, 2003 | 12:04 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Currently I'm running a 4 channel sony for my 2 front 4x6 Boston Accoustics and rear 6x9 Kenwoods. I now also have 2 JL 10-W0 subs and was wondering if I should just power them off of the existing rear speaker connections giving them 45 watts a piece. I Semi wired it in and the subs shake the car already with just the power off of the HU. Should I get a 2 channel 250 watt amp or no?
Old Apr 10, 2003 | 12:26 AM
USArmy45K's Avatar
If I was you, I would definitely amp 'em, if you think they sound good now, they;ll sound WAY better with an amp.
Tim
Old Apr 10, 2003 | 12:44 AM
kingrobert's Avatar
get the amp
Old Apr 10, 2003 | 01:10 AM
kingrobert's Avatar
get the amp
Old Apr 10, 2003 | 01:50 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
amp
Old Apr 10, 2003 | 10:20 AM
savboy912's Avatar
amp her up!
Old Apr 10, 2003 | 12:08 PM
racing_dude_17's Avatar
you would do more damage clipping them than you would overpowering them
Old Apr 10, 2003 | 07:54 PM
68Beater's Avatar
another vote for the amp...Those JL's will rock when amped...You can run the 4X6' and 6X9's off of the deck and they will sound decent...
Old Apr 11, 2003 | 03:00 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
You will never regret getting the amp, but if you don't get the amp you will always wonder. Plus no system really sounds great without an amp. They may sound good, but not great. You can always turn the subs off for that regular sound once you got the amp, but you won't.
Old Apr 11, 2003 | 12:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree, get the extra amp.
Only downside is running the new wires. You might want to reconsider your power setup for the single amp; maybe you want to get a single, thicker power wire from the battery, going into a fused distribution block by the amps, and then splitting into two power wires, one for each amp.
Old Apr 19, 2003 | 10:38 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
get the amp. Running your subs off your 4ch while its already got your rears on it is not good.....not to mention that you prolly dont have a crossover going to the subs which means your throwing raw audio to the subs instead of filtering out the higher frequences.
Old Apr 20, 2003 | 12:40 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I dont have anything running off of it right now rears and fronts are off the amp. Its going to be hard getting an amp to work cause my HU only had 1 set of preouts so we ran it back and split it and now with the new amp if i get one i cant split a splitter.
Old Apr 21, 2003 | 01:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Why can't you? Heck, buy an external crossover that takes one set of inputs and decodes it into three sets of outputs... do they still make those anymore?? Maybe you can find one on eBay.
Or just get some RCA y-adapters; one channel into two channels. Or make sure that if you get a subwoofer amp, it has a "passthrough"- one set of RCA inputs and a set of full-range RCA outputs- you can find this on higher-end amps. First you feed your RCA wire into the sub amp, and then the sub amp drives the normal amp.
Old Apr 21, 2003 | 02:54 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I have the splitters already for the front speakers and the other splitter for the rear speakers. How do I go about splitting that again for the sub?
Old Apr 21, 2003 | 03:04 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
running subs off the deck is like putting slicks on a kia.
Old Apr 21, 2003 | 03:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
This is like what you'd need. Takes one set of RCA's and creates three outputs: http://www.crutchfield.com/cgi-bin/S...o&i=575RFQ1201
Then again, might be cheaper to just buy a new head unit with 2 preamp out's, and use a sub amp with a pass thru.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
