Box carpeting 101
Old Apr 18, 2003 | 12:53 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Box carpeting 101
Yall help me with some tips on how to carpet my box and make it look halfway decent. I tried cutting the carpet out for each section of the box but that only left some exposed corners and that looked ghetto. I got plenty of carpet, I can do the flat surfaces easy but when I get to a corner I start sweating.
Thanks.
Old Apr 18, 2003 | 02:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The easiest way is to "unfold the box"
I've attached a pic to help for a rectangle box with 5 sides to cover (not the bottom). The dotted lines are the folds.
BTW, this is the quick way, and your measurements have to be right on.
Old Apr 18, 2003 | 02:48 PM
AJ_92RS's Avatar
Opps..... double post.
Old Apr 18, 2003 | 02:49 PM
AJ_92RS's Avatar
This is the long way, but it keeps all your seams off the corners.
Leave that 45* flap to fold over the side. After you fold down #1, then #2, wrap #3 around so it sits on #1. Hold it still and cut #1 along the line that #3 makes from sitting on it.
A staple gun makes this easy. Once you get everything cut-to-fit, pop the staples out, lift it up and spray 3M adhesive under there.
Old Apr 19, 2003 | 03:29 AM
onebadwagon's Avatar
lots of staples. hehe
i used woodscrews on my amp rack.
lmfao, but it worked.
adam
Old Apr 19, 2003 | 02:42 PM
AJ_92RS's Avatar
There isn't any reason you can't do the second pic with 8 staples before you pull them out and glue.
Old Apr 19, 2003 | 07:45 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Alright
i will give it a try and see what happens. Thanks.
Old Apr 19, 2003 | 08:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I don't like making my carpet edges on the edges of the box. There's way too much potential for them to separate. What I do is carpet all 4 sides (assuming this is a rectangular or wedge-shaped box), and on the bottom join the carpet. Overlap it, make 1 cut with a straight edge and a razor, then fit them together. Once you do that, you can deal with the edges. I'm not really sure how to describe how I do the sides, but I guess you could say I cut the carpet in an "X" pattern coming from the 4 corners. For example, fold the top and left flaps down, and use the straight edge to cut 1 line to the center of the panel. Remove the excess and put those 2 together. Repeat with all sides until your seam winds up being an "X" from all 4 corners. After a little practice, you can get them looking pretty good, and with the right style of carpet, it can be real hard to even find the seams.
Old Apr 19, 2003 | 08:39 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
I think I understand what you are saying, so all the seams will be going down the middle of each side, or will the top and bottom have the x after the wrapping and glueing.
I can almost follow you on that.
Old Apr 19, 2003 | 11:31 PM
mcss383's Avatar
Use a lot of extra carpet and stretch it over the box. You can easily cover 4 sides without a single seam, 5 is also doable but is a little more difficult. You just need to spray both the carpet and the box with glue (3M Contact 80 works good) before you start and staple the carpet onto the 1 or 2 sides that you didn't cover. After thats all done just use a razor blade to cut out the speakers holes and trim off the excess (which will be a lot).
Old Apr 21, 2003 | 11:10 AM
jawzforlife1's Avatar
here is another design
Old Apr 21, 2003 | 11:48 AM
AJ_92RS's Avatar
That's basically what mine looks like except the bottom.
Why cover the bottom when, in our cars, nobody's going to see it?
If you read I said "cut #1 along the line that #3 makes from sitting on it." That's what keeps the seams from sitting on the edges.
I guess the major point is, there's no reason it can't be done with one piece and the seams shouldn't end up on the edges.
Old Apr 21, 2003 | 12:07 PM
When I made mine, I didnt put any "flaps" on it at all. First I spray painted all the edges black, just in case some showed through you would notice them, Then I glued the carpet on, by rolling the box on the carpet one side at a time. As each side got glued on I would trip off the excess carpted hanging off the sides. So you would see the corners of the box. Then When I folded the sides in I trimmed the edged too. I never had and carpet overlap another carpet, and you cant see any wood on my box.
$750 L98
Feb 1, 2025 02:25 PM
Ed1LE
Sep 30, 2018 09:14 AM
Zell1luk
Sep 29, 2015 10:36 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
