Eclipse player won't eject CD or play.....
Old May 14, 2003 | 07:41 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I was cruising along when the CD started to skip. I figured it was dirty and let it go, but a few minutes later the CD stopped playing and the CD player flashed a "info 3" code. Which when I looked it up in the manual says its a dirty disc. Goes on about the CD player rejecting discs, or not ejecting them. But it DOESN'T say how to manually eject a CD from a slot loader. I can't find a pin hole to use a paper clip with like you would on a tray loader so I'm asking you guys.
BTW, eclipse has kept their damn mouth shut about this and I can't get a response by email. Actually, I've never gotten a response from them about any of my queries.
Does anyone know how to eject a disc without taking the head unit apart? Any place to stick a paper clip to eject it?
Old May 14, 2003 | 11:46 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Needle nose pliers
Old May 15, 2003 | 12:02 AM
FruityOne's Avatar
I'm not taking a pair of needle nose pliers to my $300 deck. Nuh uh. I'll sooner buy another just like it and switch them before I do that.
No offense taken at your response. I'm just as lost here. I think I might be taking the deck apart this weekend. At least its just a ol' CDR, and not a CD I actually paid for.
Old May 15, 2003 | 10:09 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
My deck screwed up like yours one time but it was because I zapped it by touching wires together, broke my heart at the time so I know how you feel. If all else fails you could always take your deck to a shop and they might send it off to get it fixed for you. Good luck
Old May 15, 2003 | 10:16 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Info 3 is a bad disc...but it should pop it out..somethin may be funny w/the deck..i'd take it in..both of mine when i get info 3 always eject..the only thing i can think of is turn it off and hit eject..maybe it'll spit it out
Old May 15, 2003 | 03:33 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
try completely unhooking the power, whether its by removing the fuse or unhooking the wiring harness. some decks ive played with, when power is unhooked (give it 15-30 sec just for ha ha's) and reconnected, it will automatically pop the cd out. you can also see if there's a reset button somewhere on the deck, sometimes that works.
Old May 15, 2003 | 10:20 PM
FruityOne's Avatar
Tried both the reset button and cutting power to the car. I have a short somwhere so I have to dissconect the battery every night.
I bought the player on Ebay as a New in box item, so I don't get the warrenty. :*(
Since I don't have a warrenty I think I'll take the deck apart this weekend and remove the disc. It won't play or eject the CD. I hope the CD didn't fracture, or shatter in there. But I think I would have heard it otherwise. It just kind of stopped playing and started flashing the Info 3. Then I tried to eject and it wouldn't do that either.
Old May 28, 2003 | 11:10 AM
FruityOne's Avatar
Fixed it, I disassembled the entire unit, greased some things and tapped the electrical motor. Put it back together and wala. It worked.
Old May 29, 2003 | 03:03 AM
onebadwagon's Avatar
good to hear you have it fixed, i havent had any problems with mine, *knock on wood*
adam
jrdturbo
Mar 31, 2016 02:58 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Linson
Oct 1, 2015 09:50 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
