DID i fry my Radio????
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
i have a 84 firebird and i was trying to find sumwhere to hook the lights on my new gauges and i didnt know where i could find a wire thats hot with acc on. so i took out the radio and i was poking the light wires into the connectors. then i put it in the BLACK/YELLOW/GREY connector that goes into the radio and it sparked. then the radio wont turn on. What did i do?? How do i fix it?? its the stock radio. please help me out.
raido
did the magic smoke come out? but you prob shot the fuse. check that.the colors are as follows.
orange=constant 12v
yellow= swiched ignition 12v
black=ground
power ant=pink
illumination=grey use for new gauges 12v
light green=right front +
dark green=right front -
tan=left front +
grey=left front -
dark blue=right rear+
light blue=right rear -
brown=left rear +
yellow=left rear -
p.s. if this is not tou're year be carefull and use a multi meter and use the outside ring of the cig lighter for ground and test for power. (if you are quazi good at electronics allwais test first)
Brian
orange=constant 12v
black=ground
power ant=pink
tan=left front +
grey=left front -
brown=left rear +
yellow=left rear -
Brian
Car: 1987 IROC-Z
Engine: 305 LB9
yea smoke came out . then i looked at the fuse panel under the steering colum but there was no fuse in the slot that said radio. so where do i change the fuse. And i can connect the lighting wire for my gauges to they grey wire and it will work when acc are on?
THANKS
THANKS
Car: 91 Camaro RS
Engine: 305 TBI LO3
If there was no fuse where it was labeled radio in the pannel, and the radio still worked, then what happened is someone wired straight power somehow right to the radio. The point of a fuse is to break when there is too much electricity going thru that circuit..so basically if there was no fuse, and the radio smoked, then yes, you fried it
Car: 1987 IROC-Z
Engine: 305 LB9
smoke came out of the connector not the radio. but the radio i have is the stock delco radio and i know the previous owner had a system in it but the wiring appeared to still be stock. so if i maybe put a fuse in that slot will sumthing happen?? should i use a 5 10 or 20 amp fuse??? i cant afford to get a new radio so i really need to figure this out. thanks again
Car: 91 Camaro RS
Engine: 305 TBI LO3
If the sticker is still on the cover, it'll tell ya what amp fuse..if not, then check in a haynes or chiltons book..regardless of where the smoke came from, im bettin ya still prolly fried it..smoke+electrical components = not good
Car: 1987 IROC-Z
Engine: 305 LB9
yes my radio works!!!!! it was the fuse i was just looking at the wrong one
but i tryed hooking up that grey wire my gauges but the lights dont get bright enough so can i use any grey wire i can find under the dash?
but i tryed hooking up that grey wire my gauges but the lights dont get bright enough so can i use any grey wire i can find under the dash? Thread
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
