Single 12" Sub
Old Nov 4, 2003 | 12:48 PM
91GTA350's Avatar
Single 12" Sub
I currently have 2 6x9 speakers in boxes in my rear tire well and an amp. I want to put a single 12" sub in between the speakers.
What type of box with fit a single 12" sub in the tire well and still leave room for the 6x9 boxes? Let me know.
Thanks,
Ross
Old Nov 4, 2003 | 12:53 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Could always custom make one so it looks good. I don't why a 12 and a 6x9 on each side would be a problem. Why are the 6x9s in the hatch and not in the sides where they are stock?
Old Nov 4, 2003 | 02:15 PM
91GTA350's Avatar
They sound like crap in the sail pannels. They sound amazing in the hatch.
Old Nov 4, 2003 | 05:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Kickpanels sound better.
Unless you close off box that the 12" is in from the 6x9's, the 12" will send the 6x9's through the hatch into the front seat of the car behind you.
Old Nov 4, 2003 | 08:01 PM
91GTA350's Avatar
I dont knoe about that, the 6X9s are pretty heavy, and i will be bolting everything down
Old Nov 5, 2003 | 04:05 AM
9177's Avatar
The pressure that the 12 will make in the box will damage the 6x9's cone. Plus with a 12 in the back you won't really notice the lower end response from your 6x9s.
Old Nov 5, 2003 | 10:58 AM
91GTA350's Avatar
Really? Even though the 6x9's and the 12" will be in seperate boxes? I may just move the 6x9 onto the shelf behind the backseat.
Old Nov 5, 2003 | 01:48 PM
Engine: 383 SBC
Well I just assumed it would be in seperate boxes... Most people know that even subs of the same type need to be seperated.
I agree though, a sub will drown out the 6x9s a little bit (You can barely hear my 4x6's or 6x9's now with my subs).
Old Nov 5, 2003 | 01:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
yeah but chris you have crazy bass now. 2 18s=craaaazzzzyyyy bass. i dont know what you hear more of in your bird. the bass or the air pressure whizzing past your ears.
Old Nov 5, 2003 | 02:57 PM
91GTA350's Avatar
Ill figure out the speaker placement, i just need to know what kind of box to buy and or build. I assume building a sinle 12" enclosure is easier than a custom fitting dual 12"
Old Nov 5, 2003 | 06:43 PM
Engine: 383 SBC
Should be... with 1 12" I'm guessing you can probably place it in the lower part of the well... unless you have one that needs crazy air space, then you would have counter for that.
Try doing a search. I would consider doing a hatch well box and just modding it for the air space you need.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
