Got a Scosche stereo kit with wiring
Old Nov 5, 2003 | 03:15 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just went to sears and picked up these two items.
Dash kit
Wiring kit
Anything else I'll need to hook it up?
Old Nov 5, 2003 | 04:46 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Butt connectors
crimpers
And if you have an 89+ (or 88 GTA), you need an antenna adapter:
Some electrical tape and wire ties are nice too. You can tie up your wiring to keep it neat and keep the pressure off the butt connectors.
Old Nov 5, 2003 | 05:48 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I think I'm going with bullet connectors. I like how they snap in, and look clean.
I just picked up a crimper, and my dad just told me he has one. So back to the store it goes.
Nice post jim.
Old Nov 19, 2003 | 09:23 AM
87 GTA TPI's Avatar
Car: 1987 Pontiac Trans am GTA
Engine: 5.0L
Transmission: Dead 700r4
v
Old Nov 19, 2003 | 02:07 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I like to use Clear Closed End Caps over Butt Connentors. I find that they are generelly better built over the butt connectors most places sell and they have one crimp over the two a butt connector has. The way I look at it is, that there is less of a chance of a short. THe downside of corse is that butt connectos make the job neater becuase they keep the wires "straight' but I feel that its worth the 'mess'
I also use the clear butt connectos when I deem necessary to use butt connectors, but mostly I like to use closed end caps.
I also recomend two other tools instead:
Klien 9" Pliers/Wire Cutter/Crimpers
Ideal Stripmaster Wire stripper
Old Nov 19, 2003 | 02:51 PM
Jim85IROC's Avatar
I absolutely dispise those strippers. There's nothing wrong with those strippers, but I never, ever got any brand to strip reliably and the way I wanted. I use a jack knife or a razor blade to strip all of my wires. But... I can't say enough for having a good quality pair of crimpers instead of the low quality garbage that you buy at Wal Mart and Parts America. I've got a pair of Snap On (only snap on tool I own) crimpers, but the $15-20 Klein crimpers are just as good. I don't personally care for the style that Stuart posted though. I don't like crimping with the backside of the pliers. It makes it very difficult to do it in tight places (like dashboards) and is just combersome. The style that I posted initially are just much easer to work with in my opinion.
Old Nov 19, 2003 | 03:26 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Crimping from the backside is cumbersome but I haven't seen any other tool personally that can get enough leverage to get a good crimp. It also allows my to crimp 4AWG so Its a compermise I quess
I had to use it in tight spaces a few times, which I would not recomend but any other crimping tool I have would not get enough leverage to crimp tight. The tool would 'max out' and the wire would slipp right out of the connector.
I will look at the Snap-On tool. Sounds promising.
Also, I have never had a problem with the Stripmaster strips anything from #10 - #22.
I quess what Jim is getting at is you have to find what tools work best for you and stick with them. Its all a matter of personal preference.
Old Nov 20, 2003 | 04:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Can I give my list, too?
Soldering gun:
<img src="http://www.radioshack.com/images/ProductCatalog/ProductImage/64/m64-2184.jpg">
Solder:
<img src="http://www.radioshack.com/images/ProductCatalog/ProductImage/64/m64-002.jpg">
Heat Shrink:
<img src="http://www.radioshack.com/images/ProductCatalog/ProductImage/278/t278-1627.jpg">
Ultra-neat, ultra-clean, and you can bet it'd last longer in a stress test than a butt connector would!
Old Nov 21, 2003 | 12:36 PM
SweetRide45's Avatar
I agree w/ TomP. I solder all my connections. I rarely EVER use Connectors. I'd say go w/ Soldering all the way. Who cares if you chop of the factory wiring harness if you have to. That's why you bought an aftermarket setup anyway, right?
I had to get rid of almost all the wiring back there, for all my aftermarket stuff. Just very limited room in that little Radio Pod.
Old Nov 21, 2003 | 02:10 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I like using the metra smartcables cuase ease of installation and at the rate I've been going through cars, I can just put the original back in no problem.
Also not everybody is good at soldering, it takes practice before ones ready to start solding the connections on ones car.
camaro11j
Sep 19, 2018 08:49 AM
fasteddi
Sep 2, 2015 10:29 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
