Bad idea to hide Nitrous bottle in Sub Box?
Old Dec 20, 2003 | 01:17 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I made my own box out of MDF almost a year ago, and had this crazy idea... I could hide the nitrous bottle in it!
I tried, it fits too! I made my box follow the contours of the entire back trunk area, and it fits 2X 12's up top which are angled towards the front.
I dont know if thats such a good idea though... getting to the bottle means pulling out a sub, plus who knows what effect the bass might have on a pressurized bottle like that!
What do you think?
Old Dec 20, 2003 | 07:00 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
putting the bottle in your box will also greatly reduce your cubic feet and your subs will then sound like ****.
Old Dec 20, 2003 | 12:39 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
ya the volume of the bottle will reduce the enclosure volume.
it would work if you had a box that was too big and wanted to reduce the airspace though
in my first couple installs i was just learning the affects of bigger vs smaller enclosures so i would purposely make the box too big and then put bricks in it to see what it sounded like with less and less airspace.
Old Dec 20, 2003 | 11:07 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Yeah well the box is most def. too big i have to keep a piece of wood nailed to the bottom to reduce its volume...
so it may work? hrmm...
Old Dec 21, 2003 | 12:01 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Bad idea to hide Nitrous bottle in Sub Box?
What do you think?
I'll have no effect on the bottle whatsoever.
Old Dec 21, 2003 | 02:23 AM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Just make sure you get a remote valve opener. Also I am sure you can fabricate the sub box to house the nitrous bottle with an easier way to access it. I saw one guy who had a cool setup. I will attach a pic of how he had it setup. Don't mind the crude format.. Also where the Nitrous bottle sits is completely sealed from both subwoofers. Its almost like having 2 independant boxes and a secret storage compartement. My buddy has this setup in the back of an integra. I am sure the same idea can be adopted for our cars with little to no problem.
Old Dec 21, 2003 | 01:26 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
if ur tank leaks even a bit, u will insta-freeze ur amp and subs.. ruining them forever
Old Dec 21, 2003 | 03:37 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
NO it wont
Old Dec 21, 2003 | 03:46 PM
92MaroRS's Avatar
that woudl be LIQUID nitrigen not gas.
Old Dec 21, 2003 | 03:58 PM
ThraxXx's Avatar
well my buddy has been rollin like that for a while now "his car is stored and bottle is out". However he hasn't had any accidents with that setup yet. Not sure how a bottle could leak, If the valve is attached properly and the lines insulation is still intact then there should be no leakage. That setup I displayed has a special area just for the bottle where the preasure created from the subs can't cause any adverse affects.
Old Dec 21, 2003 | 04:53 PM
Daishi's Avatar
Strange, My buddy has his tank leak and it froze up his trunk.... oh well whatta i know about nitrous. I just press the gas pedal and my sweet *** V8 delivers the juice
Old Dec 21, 2003 | 07:19 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
The bass might eventually loosen things... ?
Old Dec 24, 2003 | 11:10 AM
ThraxXx's Avatar
If the nozzle is locked properly then it shouldn't loosen unless you use the allen key to pop the lock off prior to twisting. If the vibrations form a sub doesn't knock your exhaust off, then the Nitrous should be ok.
Old Dec 27, 2003 | 12:49 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
you might get a weird noise with a bottle in your box. I'm not sure about NOS bottles but a scuba tank makes a nice ring when you tap on it. It even resonates when you speak loud near it. I'm guessing a NOS bottle would behave the same way.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
mx127
Aug 10, 2015 08:13 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
