subs in trunk, horizontal vs slanted
Old Jan 22, 2004 | 01:05 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Ok, i know that the hatch helps redirect the sound of the subs.. but is there a difference in the way the sub perfroms ( or at least sounds to the driver) if the subs are angled forward or facing straight up
Old Jan 22, 2004 | 02:00 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
some people say the get better SQ facing forward but not nearly as much SPL..i could be wrong though, i havent worked with 3rd gens all that much
Old Jan 22, 2004 | 08:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I haven't found the orientation to be a major factor. There really isn't enough room to drastically change the direction that the subs face in the back of a thirdgen anyway. I did build one box that had the sub facing straight back and I was happy with it, but the rest of my boxes have always had them facing straight up. Tilting them slightly forward or slightly back won't do much of anything except make it look different.
If you're really serious about sound quality (especially if you compete), then there may be some advantage to having the subs face toward the back of the car, because you'll be less likely to hear some of the resonances and higher harmonic frequencies that radiate from the cone surface of the sub. These higher harmonics aren't necessarily audible, but are recognized by the brain and cause you to be able to localize the source of the sound to the rear of the car instead of up front where it should be focused. But... this only really matters in extreme cases. Unless the back of your car is heavily damped with dynamat (or some equivalent), you're going to get enough resonation from the body panels that it'll far outweigh any harmonics that come from the sub, and you're going to be able to localize it anyway.
Old Jan 22, 2004 | 08:03 PM
Ericritter7407's Avatar
Car: 88 Camaro Iroc-Z
Engine: 350 carbed bored 30 over
i have my back seats folded down with my box on top of that, but then im screwed out of two back seats. I think im gunna try and build a box for the trunkfacing straight up so it will reboud of the hatch. I have two 450 legacy subs with a legacy 600 by 2 amp and custom box
Old Jan 22, 2004 | 09:50 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
legacy fabulous
Old Jan 22, 2004 | 10:03 PM
OutLaw305's Avatar
i had 3 10" polks sitting on my back seat.. time for a change
Old Jan 23, 2004 | 11:36 AM
haha the lagacys were cheap but sound pretty good
Old Jan 23, 2004 | 04:44 PM
WhyHelloOfficer's Avatar
Car: 1994 Camaro Z-28
Transmission: A4
I've got two solobaric 12s sitting in the back of my '92 RS. They are flat, and I get good SPL as well as decent SQ. Granted... it could be better if I had a CD that didn't skip when it gets turned up louder... and a cap so my alternator doesn't crap out on me
-Joe Bliz
Old Jan 24, 2004 | 08:53 PM
what amp do you suggest for the rest of my speakers
my 6x9's and such to keep them from crackling
Old Jan 25, 2004 | 08:57 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
what amp do you suggest for the rest of my speakers my 6x9's and such to keep them from crackling
Uhmm if your highs are crackling, I dont see how giving them more juice is gonna help anything, Maybe blow them? If you have good highs, they sound good off the deck and even better with an amp...If yours are crackling, dont amp them, let them die a slow death!
Old Jan 25, 2004 | 02:28 PM
thug_boy0703's Avatar
Car: 1991 camaro
Engine: 305 H.O.
Transmission: 700r4 automatic tranny
well i have two alphasonik 10's facing the glass in my ride and they sound really good so i think they sound really good firing at the glass
THEY HAVE V-TECHS
WE HAVE V-8'S
Old Jan 25, 2004 | 02:57 PM
semiller26's Avatar
Car: 1986 Trans Am
My Infiniry Ref. 12's (2 of them) are angled slightly forward any slight ly out. I don't know if this helps any but the integration of the subs with the rest of the system is very good the bass feels like its coming from the front as it should in a good SQ system. The rest of the system consists of custom designed components and a modified alpine 5 channel amp.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
