alternators
Old Feb 21, 2004 | 05:33 PM
blaze1's Avatar
Car: 1989 iroc
Engine: l98 tpi
Transmission: ????
alternators
Hello im about to do my system in a few weeks and i want to have it clean and have as little problems as possible. What kind of alternator and batterie should i get for my ride? I have a 89 5.7 tpi and i will be running a after market stereo with aftermarket speakers and 2 subs and a amp. Any advise or examples from your rides would help.
MCL Blaze
Old Feb 21, 2004 | 05:56 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
depends on the amp you plan on running you might not need to upgrade either
Old Feb 21, 2004 | 06:23 PM
blaze1's Avatar
Car: 1989 iroc
Engine: l98 tpi
Transmission: ????
Im going to be running this amp
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18796
I know its over rated
Old Feb 21, 2004 | 07:56 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
well i wouldnt woory about upgrading the alternator yet, id install it and see if you have any problems...id upgrade the wires those
wire from battery to alternator
wire from battery to ground
and engine ground
upgrade to 4 gauge wire( can be found in installs kits from walmart
yeah, see if you tsock electrical can support the upgrades then id worry about the alt, but you dont see to be drawing to much power, so you'll probably be ok
Old Feb 21, 2004 | 08:08 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
^ Actually, if you're planning on doing the big 3 upgrade like mentioned above, I'd go with 0 or 2 awg wiring > 4 awg. Just because the bigger = the better. Obviously, there's a limit, but the whole reason to do it is to free up the resistance.
And I'd definatly get a bigger alternator for that amp. You're gonna have problems. I'd say look for a 160 Amp+ alternator. There's some good places to buy 'em online, if you're interested in links.
Also, I'd go with AT LEAST an Optima Red-Top, if not a Yellow-Top.
Old Feb 21, 2004 | 09:00 PM
blaze1's Avatar
Car: 1989 iroc
Engine: l98 tpi
Transmission: ????
Yea i got a yellow top batterie in my garage i just have to yank it out the other ride. Do you know any sites that have *** prices and alts?
Old Feb 21, 2004 | 09:11 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
yes bigger wire is better, but like i saif 4 gauge is alot easier to come across. and more than enough for that amp.
If im correct those SPL amps are made by power acoustik and are extremely overrated.
theres no sense in spending 250+ bucks on a high output alternator if you dont need it.
but if you need an alternator check out www.4alterstart.com
Old Feb 21, 2004 | 11:52 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I just upgraded my alt to 140 amps and did the big 3 upgrade, I have never had any problems
Old Feb 24, 2004 | 10:59 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Any good local alternator shop can convert a stock alternator to put out 120 amps, which SHOULD be plenty.
Old Feb 24, 2004 | 06:06 PM
blaze1's Avatar
Car: 1989 iroc
Engine: l98 tpi
Transmission: ????
cool i think thats what i will be doing
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
