Running 12's and 10's?
Old Apr 6, 2004 | 07:16 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Ok, as some of you might has noticed..Im new to the whole sound system side of things. But, I have another question.
I bought a new Ultimate amp(335w)+Memphis sub(12",475w) audio combo, it sounds pretty good. But, I came acroos a good deal on a Rockford sub(10" 300w) and a Kenwood amp(200w) audio combo. So I bought it.
Could I run the 12 and the 10 together? Or would it sound like crap?
Old Apr 6, 2004 | 08:21 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
you'll prolly get cancellation, meaning its gonna sound bad.
Old Apr 6, 2004 | 08:31 PM
CaysE's Avatar
What nibleT meant to say was you can do it if you want. You won't get cancellation (especially since they're not the same sub) as long as you wire them correctly. Personally, I think two different subs won't be particularly good looking, but it gives you a good range of sound to play with if the 10" handles slightly higher frequencies better. Go for it.
Old Apr 6, 2004 | 09:23 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
It doesnt matter if they are the same sub, typical newbie comment their. On paper a 10 and a 12 move a different speeds and this is what causes the so called "cancellation" I would stay with the 12 or the 10 but not both.
Old Apr 6, 2004 | 11:10 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
this is totally correct...generally most people wont have different subs playing the same frequencies. Now if you want to have your 12 playing 20-40hz and your 10 playing 40-75hz that could work but i dont think its really worth it. My first setup was 2 12s, then i upgraded to 2 higher quality 10s, then got the idea of putting both sets in together and it didnt sound too good at all especially when running all 4 subs off of an explode amp at 0.33 ohm
if you got a good deal on the sub as you said, it should be too hard to find another buyer for it.
Old Apr 6, 2004 | 11:30 PM
CaysE's Avatar
My apologies, nibleT; I was thinking of the kind of cancellation when you wire one sub out of phase of the other.
Old Apr 7, 2004 | 09:08 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I'd sell the stuff and buy an entire setup that works well together.
Old Apr 7, 2004 | 09:39 AM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
no problem bro, we all have our own opinions.
Old Apr 7, 2004 | 12:13 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The only reason the subs are moving at different speeds is due to amplitude differences. The fact is, the frequency is the same, and the phase is the same. There will be no cancellation due to driver size differences.
The problem lies in the different frequency responses and sound characteristics of the drivers. Because the two subs don't have identical frequency responses, instead of a response that may be +/-3dB within the passband, you could wind up with irregularities of up to +/-6dB. Furthermore, distortion levels and other differences that contribute to a driver's overall sound quality will be vastly different. When you blend the two together, you typically wind up with sound that's worse than the worst of the two individual drivers.
Old Apr 7, 2004 | 02:44 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Amen....
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
