grounds
Old Apr 15, 2004 | 05:53 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
grounds
hello all,
I was just wondering. Where did you all ground your amplifiers out to. When the guys installed my subs they grounded out the amps to the bracket that is used to hold the folding back seats up. I knowthat this is not a good idea as that part moves so I wanted to relocate the ground. Where would be a good spot.
thanks
Old Apr 15, 2004 | 06:19 PM
CaysE's Avatar
Anywhere you find a screw hole in the body... or just drill your own. Just beware of the gas tank.
Old Apr 15, 2004 | 07:31 PM
onebadwagon's Avatar
if your amps are in the rear, down along the passenger side by the spare tire, there is a straight stretch of frame, ground it there.
grind off more paint then you think is necessary to get a GOOD ground, and then shoot a few screws through a ring terminal.
Old Apr 15, 2004 | 08:47 PM
ThraxXx's Avatar
Well I posted a pic of my install in another thread but here it is again. This is so you can get a better idea at what I have.
Old Apr 15, 2004 | 08:49 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
ooooooh pretty.
Old Apr 15, 2004 | 08:55 PM
ThraxXx's Avatar
I just wish that it would work. It worked for about 20 minutes...then the ground fell off the mount and I don't have the proper tool to remove the bracket to relocate the ground. Gonna have to bring it back to the shop tomorrow and get it properly grounded.
Old Apr 15, 2004 | 08:58 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
dude you can ground it pretty much anywhere just do this.. turn everything on and touch the ground wire to crap you think is safe too ground to... if its good youll get a spark and if u catch it good ur stuff will turn on and start bumping.
Old Apr 16, 2004 | 01:06 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
mine runs behind the left side rear panel to where the mount for the rollout cover would be
Old Apr 16, 2004 | 05:51 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
I actually have mine grounded to the screw in the hatch. its a small screw but it does the job.
Nate
Old Apr 16, 2004 | 10:40 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
since my amps are a big part of my rear seat, one of the seatbelt bolts worked great
Old Apr 16, 2004 | 11:30 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
OMG NO! DO NOT DO THIS!
You have no idea how bad this is for the HU.
This is with out a doubt the worst piece of “advice” I’ve heard on this board in a long time.
A bad ground at the amp CAN KILL the HU, and you're intentionally making a bad ground at the amp.
Doing this the amp will try to ground through the RCA cable, back to and through the HU.
THIS IS NOT A GOOD THING!
NEVER DO THIS! :nono:
Old Apr 16, 2004 | 02:35 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
hmmm maybe i shoulda mentioned to make sure ur amp isnt hooked to the HU. just to power. when the amp turns on u have found a ground. my bud did this for another friends car.. we removed the HU and hooked everything up execpt the HU to the amp.
Old Apr 16, 2004 | 02:58 PM
ThraxXx's Avatar
Well today I re-did my grounds. I used my dremel tool to grind away some pain underneats that plastic covering in the rear by the seat belts. I then put one of those eye pieces on my ground wire and screwed it directly to he chassy. Ground was good but the amps still weren't firing.
This frustrated me so then I busted out my volt meter and low and behold, the ground was not the problem...it was the power line. I examined the fuse and yep...it melted. SO!! I went to Stereo plus and bought a replacement gold plated fuse rated at 80amps. Its made by pheonix gold and came in a nifty package and costed me a big 9$ so it should do the trick. When I talked to the guys at the Stereo installation place they stated that the fuse they used was the one that came with the fuse holder and they aren't exactly grade A fuses.
Well I am happy that its back up and running cuz I like bass when I drive.
Old Apr 16, 2004 | 03:06 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
lol good to see that you got it working.. on a side note what is under the plastic panel by the rear seatbelts?? i wnna mount a speaker there..
Old Apr 16, 2004 | 09:06 PM
ThraxXx's Avatar
Behind that plastic area behind the seat is the wheel well. Not sure if you could put a speaker there. I say your best bet for speaker is building a small MDF box that will fit in that sail panel location and run some 6.5" components there. Thats my plan. Should sound freakin sweet!.
Old Apr 18, 2004 | 07:03 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
aight i didnt want to take the plastic off... i was at circiut city and best buy listening to the speakers... 6.5s do sound alot leaner and full IMO. sony speakers just plain suck...
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
