drilling hole for amp line ?
Old May 22, 2004 | 11:59 AM
ajmcmahon's Avatar
Car: Pontiac Trans Am
Engine: Stock 305
where did you guys drill your hole for the battery to amp line ? how much of a pain is it ? do i have to take apart the dash ?
Old May 22, 2004 | 01:21 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
On the bird i drilled mine on the drivers side in the little corner there of the firewall. YOu can feed the wire through and pretty much feel it come through by just pulling off the kick panel. The rs's i just did yesterday and just had to make my exsisting hole bigger as there was already a hole there for my alarm wire. ANd my stereo wiring was 8 awg. Just make sure you put a grommet in the hole before you feed the wire. THe hole is right next to a cable that runs through i think its for the cruise control.
Old May 22, 2004 | 07:31 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
its ur hood release latch. i know becuz i ran mah wires for mah fan thru it
Old May 22, 2004 | 08:35 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
That is exactly where I put mine
Old May 24, 2004 | 09:09 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
On cars that have the battery on the passenger side, I've found the passenger side kick panel, an inch or 2 away from the antenna grommet, to be the best spot. On cars with the battery on the driver's side, I drill a hole in the firewall in the vicinity of the clutch master cylinder.
Old May 24, 2004 | 11:52 AM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
on cars that have an auto and drivers side battery, there should be a big grommet where the clutch pedal would be, worked good for me
Old May 24, 2004 | 12:09 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
do our cars have that so called grommet cuz ive yet to see it
Old May 24, 2004 | 02:12 PM
Jim85IROC's Avatar
No they don't. I've done an auto to manual conversion, and I had to cut the hole in the firewall.
Old May 24, 2004 | 05:46 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
I THOUGHT SO!!!
Old May 24, 2004 | 06:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've got that grommet on my '86. Didn't realize it was a grommet, though, for my first amplifiers... and drilled two holes (one for each power wire) thru the firewall on the driver's side. I realized it was a plug later on. Maybe it's year-dependant? My battery is on my driver's side, and I also have an automatic- and my car's an '86.
Remember to drill from the "inside" of the car towards the engine. There's a ton of stuff in the dash that you don't want to drill into!
Plus, you can use all the stuff in the firewall to "locate" the exit point of the hole you're going to drill. Yeah it's a pain, but it's more of a pain in the neck (literally) than "technically hard".
When I punched out the firewall plug, I used a hammer & punch to knock it "in" towards the engine. Any '86 guys here with auto trannies want to verify that the plug exists?
Old May 25, 2004 | 07:30 AM
Jim85IROC's Avatar
My buddy did a swap in his 92 and there was no grommet either. Nobody that I've ever talked to who did the 5-speed swap was lucky enough to just have to pull out a grommet... we all had to cut holes. I don't know what that grommet is for, and why some cars have it, but I can't imagine it's for the clutch.
Old May 25, 2004 | 03:23 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
well the slave for the coutch should be near the brake master cylinder so.....
Old May 25, 2004 | 03:54 PM
Jim85IROC's Avatar
no kidding sherlock. I know exactly where it is. I also know that the factory 5 speed cars (I have a couple of those too) have a 2nd reinforcement plate welded to the firewall on the outside that the automatic cars don't have. The 5 speed cars have more differences from the automatic cars than people realize, so I find it highly unlikely that somewhere after 85 and before 92 that GM decided to make the cars the same and just add a rubber grommet.
Old May 25, 2004 | 04:26 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
I did not have a hole either when I swapped in my T56.
Old May 25, 2004 | 07:49 PM
brannonh's Avatar
Car: TRANS AM GTA
its there
Guys I still have my car apart and the grommet is there. I have a 89 gta. If I can, I will take a pic a show you where its at. Brannon
Old May 26, 2004 | 11:37 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
pics yes
you may be talking about something else but pics would help
Old Jun 1, 2004 | 11:20 AM
purplenurple92's Avatar
Car: 1992 RS
Engine: l03
you don't have to drill a hole. there is a gromit on the driverside where the steering column meets the fire wall
Old Jun 1, 2004 | 11:32 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
............................................................................................................... i can't believe you did that..... well i have a 91 RS with auto i'd go outside to check it out but it's like 1 million degrees outside and ten times hotter in mah car.
Old Jun 3, 2004 | 10:36 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
After working in a stereo shop for a short time, I found that almost every car has a place to sneak a wire through.
Thirdgens definitly have a few places to pull some 8awg through.
Some cars even have places to pull 4awg through, some have good power taps on the interior fuse panel......but that's still a little 'hack' IMO considering you're pulling power through two fuses. The battery is the only place to connect to in my book.
After awhile, I found myself using my 'fishing rod' more and my drill less and less.
Old Jun 7, 2004 | 12:52 AM
PontiacRacing's Avatar
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
My buddy and I drilled in the spot right under the brake master cylinder. Its really easy to hide the wire under the hood doing this.
Old Jun 7, 2004 | 03:10 PM
CaysE's Avatar
Battery is on the passenger side on my car. I drilled a hole behind the passenger kick panel and routed it behind the fender into the engine bay. Wire loom all the way.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
