will subs work on my 4 channel sony amp
Old Aug 2, 2004 | 11:10 AM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
i used to have a 480 watt amp powering my 10" sony xplod subs but i let my brother borrow it and he blew it up so then i bought a 800w sony explod amp, but when i hook the subs up to it i get no *** at all...i found out that its a 4 channel amp...id there any way i can get it to power the subs the way a 2 channel amp would
Old Aug 2, 2004 | 02:34 PM
rrcustom's Avatar
4 channel amp to 2 channel amp
You must bridge your channels to make your four channel amp to a two channel amp. Basically you take on the first two chanels the positive on the first channel and the negative on the seond channel to make one channel. To do the second channel all you do is the same thing. You take the third channel positive and the fourth channel negative to make the second channel.Hook your subs up that way and now you have a two channel amp that was once a four channel amp.
Old Aug 2, 2004 | 03:51 PM
Car: 92 camaro RS
thanks man :hail:
Old Aug 2, 2004 | 08:18 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
remember its a sony which is **** with amps and it might keep overheating if you dont follow the specs
Old Aug 2, 2004 | 08:41 PM
Car: 92 camaro RS
ive never have had problems with overheating
Old Aug 2, 2004 | 08:56 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
Almost every Sony amp I've seen will release the magic smoke if you attempt to power a two ohm load or bridge the channels.
read the paperwork carefully before you reach the point of no return.
Old Aug 3, 2004 | 05:46 AM
Car: 92 camaro RS
even if its getting pletty of cool air ?
Old Aug 3, 2004 | 05:48 AM
Car: 92 camaro RS
the system i have no is just to hold me over until i have the money saved for a nice one...what brand amps+subs would you recomend
Old Aug 3, 2004 | 07:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I remember when I went to Sony Training back when I sold that crap. It was the 2nd year for the xplod line. At the time, their mono bass amp was rated at "1 ohm stable". Even the Sony district rep couldn't say it with a straight face.
Old Aug 3, 2004 | 09:24 AM
Car: 92 camaro RS
thanks guys...i havent had any problems with sony...i have sony everything including a sony home theater system and tv and i cant complain for the price
Old Aug 3, 2004 | 10:43 AM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
just read carefully try sounddomain.com find your amp and read comments of what not to do and such i also have a sony home theater but id never put a sony product in car
Old Aug 3, 2004 | 10:57 AM
Car: 92 camaro RS
what brand equipment do you have in your car and how does it sound and how much does it go for cause im thinking of ideas for my new system i want this is just a temp.
Old Aug 4, 2004 | 04:12 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
well i was on a budget i wanted to spend under 250 total for my sub amp wireing and box
i went the day after christmas for all the sales bought
KAC-7201 kenwood amp after weeks of research for my budget this was the best built in fan and a good wattage and good reviews
with 1 sub bridged it pushes 460rms 800 peak
http://www.kenwoodusa.com/product/pr...productId=2477
got it at circuit city for 150 i believe
then for a sub i was leaning towards a p miller but it was alittle outta my budget and ive always liked infinity so i got
http://www.circuitcity.com/detail.js...&oid=71445&m=0
1200 peak 300 rms but know to take alittle abuse from amp so i could push alittle more which i dont
got that for 63 bucks
wirering 20 bucks
box 15 in supplys built it myself
but thats for a cheap system if i crank it all the way up u can feel your hair vibrate and all so its enough for me i dont need to be hear a block away just enough bass to match the loudness of a stereo nicely
but if u want somthing nice p.millers bazooka dual voice coil 12inch sub hit hard and nice and smooth
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
Irocohio
Aug 12, 2015 08:03 AM
