This a good idea?
Old Dec 28, 2004 | 03:14 PM
spearson's Avatar
This a good idea?
I've been thinking about subs lately, but I hate how much room they take up. And I'm not the person that needs a ton of low bass, I don't want obnoxious, I just want crisp overall sound.
So I was thinking.. Would it work to mount say, an 8" sub in the two rear corners of the trunk? Mount one where that little storage compartment is, and another in the corner where the spare tire is. It would be a small enclosure so would a solo-baric or something work?
Old Dec 28, 2004 | 03:26 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
Try some RE 8's or some Tangband 8's aswell, both offer great soundquality for a small price tag. If you don't mind waiting elemental designs has some new kv.2 9's coming out, that are on a special pre-order price. Make a box for the bottom of the well for better results imo.
Old Dec 28, 2004 | 06:41 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
build either a small down-firing box for 10's or 12's, or build a normal small box with speaker grilles to protect speakers--then you can utilize the area still...
Old Dec 28, 2004 | 08:38 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
be careful not to build the box too small because the box i got is one size fits all 12" ( not really ) and is really big for the car but too small for the speaks and they distort at high volumes.
Old Dec 28, 2004 | 09:00 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
you could get a buzuka tube with a 8" that will fit on the hump betwen the back seats and most of the are self amped so less wireing. this will give you that sound you are looking for. It can also be mounter other places it is anound 2 feet by 7 in or so
Old Dec 29, 2004 | 12:14 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
A high quality 10" with 300 watts RMS would be fine for your needs. Put in a DVC with 600 watts RMS and it'll be plenty loud
Old Dec 29, 2004 | 12:53 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
using RE8s in a good install you'll still be fairly loud. Its definitely doable
Old Dec 30, 2004 | 10:22 AM
ScrapMaker's Avatar
I wonder how that bazooka tube would sound in the middle of the back seat like that.... could be kinda weird... plus the further away the sub is from your ears, the deeper the sound is
Old Dec 30, 2004 | 12:42 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
To your original question, yes, it is very feasible to put subs in those locations and has been done many times.
Old Dec 31, 2004 | 05:52 PM
NjccBflo's Avatar
Run a pair of 8's isobaric. Itty bitty box. Sounds fine, not as much output. Ran a pair of CV 12's in my truck for a few months.
Old Dec 31, 2004 | 06:25 PM
GTAfanatic's Avatar
the bazooka tube only gives the deep bass unlike other subs where you can still hear the words even though the amp is set to LPF. this set up gives you that small amout of bass he is looking for if you like to feel and hear lots of bass then you should put a 12' in the back.,
it not the further away the sub is, the deeper the sound is you get that afect from the bounce around when the sound bounces off the glass it reflects the low bass and destorts the high's that why you hear a different bass.
Also for car with a trunk the subs should face the open of the trunk not the back seat by doing this the subs use the hole trunk as a box that is why truck and blazer shoud so good.
Old Dec 31, 2004 | 06:36 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if your amp has a good crossover in it...you shouldnt hear anything but the frequencies you want to come through
Old Jan 1, 2005 | 01:08 AM
ScrapMaker's Avatar
yeah actually my amp is set to PASS THROUGH.... I just use my deck, and it's perfect...
in fact, if I use the amp crossover, then the deck gets mad when I do the AutoEQ/AutoTA
Old Jan 1, 2005 | 04:46 PM
spearson's Avatar
thanks guys
CarGuyDennis
137
Dec 6, 2016 11:02 PM
mdtoren
Aug 23, 2015 12:52 PM
Cripley
Aug 17, 2015 03:35 PM
BurlyChev
Aug 16, 2015 09:08 PM
mdtoren
Aug 16, 2015 05:45 PM
