Amp Mounting Location
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
How do you guys mount your amps, I have my kenwood 4channel wired up but i dont know how to mount it, i know the gas tank is right there, so how do u do it?
Car: Camaro
Engine: 3800
mine fit in the compartment in the back, side. Had to take the cardboard box out for mine... x541 is the one I have, for size comparison anyway...
It's be held in by styrofoam sheets wadded up, tightly packed. Amp is very stable... I can actually hit it and it moves enough to dampen vibrations, that's it. Gotta make sure it can still breath out of the fan in/outlets though.
-Bud
-Bud
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Originally posted by z28cmr83
will the velcro hold up on hard cornering?
Car: 00 TA, 91 Formula, 89 RS
Car: 1991 Camaro RS
Engine: 357cid
build an amp rack to go over the gas tank hump... like a box for you amp sort of..
Car: 83 Z28, 84 Z28
well how far do i have before i hit the gas tank, can i just drill it in?
and do you have any pictures of a simple box that would go over the gas tank hump?
Car: 1986 Firebird
Engine: 2.8 V6
You don't even have to drill into the hump. Remove the side plastic from your car. Buy steel strip stock from Home Depot in the hardware aisle. Then make brackets to go from the side of the car (behind the plastic), to bend down flat against the carpet, and stick out in the passenger area. Then you can bolt your board to those homemade brackets.
Car: 1991 Camaro RS
Engine: 357cid
Originally posted by FyreLance
If you get the good stuff. Get heavy duty stuff from a hardware store. I never had a problem.
Do you have T-tops? If so then you can use the 2 little anchor bracks under the carpet that are used to hold the T-top bag in place above the gas tank. They mine have a pair of threaded holes in them for the anchor screws. I've never looked to see if these are standard on all thirdgens with and without T-tops, but it might be worth checking. Of course, if you've already checked under the carpet and there weren't any brackets, then you're probably out of luck. Here's a quick pic of one of them (sorry about the crap in the background, I'm just in the process of installing the last bit of sound deadening material in my car):
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I had mine on an angled shelf built above the left sub when I was running 2 12's. Then I took one of them out, and I just put the amp down overtop of the hole, and had all the wires going down inside the box. I cant find a pic of the shelf right now, but here is one with the amp sitting level.
This other one is from the 86, and you can see that both boxes are constructed pretty much the same. The only difference is, on this one the amp is on the underside of the top board. Now that's just sexual.
Originally posted by Saigon_Bob
i personally (with my $300+ amp) will never trust velcro to the forces of a car cornering with the kinda weight that an amp has
I even autocrossed with mine IIRC
I've got a box of 12's and the amp in my trunk, nothing is bolted down, it's a pretty small trunk so the box has dosen't move much, and the amp stays right beside it on an angle, not bolted down. I've taken some hard turns, done doughnuts, spun out, the amp/box haven't moved, so I figure it's not really that big of a deal and even simple velcro will hold it in place.
It wouldn't help if you were on a track pulling higher G's, but if your car is doing that maybe it shouldn't have that extra weight in it =)
Whatever you do, don't bolt it to the top of the speaker box like the morons down here do. I would bolt it to the side like 87tpi
Car: 83 Z28, 84 Z28
what if i put it below... all the way in the bottom of the hatch, and then put a Q-logic 2-12" box on top of it, would it get enought air?
Have you considered putting it in your rear seat? It's not that tricky, I just did it with two amps and a crossover. I'm waiting on a 4th gen seat set to swap over otherwise it would already be in my car. I'll post more pics when it's done, but here's one of the amps mounted in the seat w/o the crossover and before putting the cover back on (the 4th gen cover is the same fit so I'll just slip that one over and cut out the holes so that the amps and crossover are visible).
Car: 89 IROC-Z
Engine: 355 TPI
And a bit of general advice. Don't mount the amp to the box. It's just asking for bad solder connection in the amp. And if you just have to mount it to the box, under stand you are more then likely cutting short the life of the amp.
Car: 83 Z28, 84 Z28
trueblue91rs, can you post a picture when you are done so I can see what you are talking about, and how it fits?
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Im gonna add...Never drill near the gas tank. You can lay wood under the carpet and drill to that. When I had my T/A I just used HD velcro.
db057
Aug 11, 2015 10:11 PM
