Steering Wheel controls....not the PAC thing....
Old May 11, 2005 | 04:20 AM
68RallySport's Avatar
Car: 68 Camaro RS
Engine: 355ci
Transmission: t-56
Does anyone have a way to adapt the steering wheel controls for an 89 Turbo Trans AM without using the PAC transmitter or other similar remote devices?
David
Old May 13, 2005 | 06:24 PM
onebadwagon's Avatar
what type of radio?
Old May 13, 2005 | 06:32 PM
Car: 68 Camaro RS
Engine: 355ci
Transmission: t-56
undecided so far. There is an aftermarket deck in already but im am most likely going to swap it out with a nicer product and one thats hopefully compatible with the steering controls....
David
Old May 18, 2005 | 02:20 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
you would have to find a headunit that supported a WIRED remote, sony and pioneer have these...
then you'd have to basically tear apart this remote, and wire it into your steering wheel stereo control wires...
good luck.
there's a reason why they make that PAC box... but I also don't like the idea of it just repeating an IR signal...
I think stereo's should come with RF remotes anyhow, so I can control them from like 20 ft away.
Old May 18, 2005 | 06:54 PM
wiring into a "wired remote stereo" won't work, because the factory 'steering wheel control' is one wire, which pulses a signal.
Old May 19, 2005 | 10:20 AM
ScrapMaker's Avatar
so then he'd have to actually open up the steering wheel and get to the buttons themselves... and with a little electronical know-how... he'd have to wire them to the new wired remote ... assuming that none of the buttons on the wired remote use ***** or dials... cuz then you'd have to do some pretty crazy stuff...
like I said, there is a reason they made that PAC thing.
Old May 19, 2005 | 12:05 PM
it's not quite that easy man.
you gotta remember that all those wires in the steering column spin when you steer, so what you're proposing probably won't work.
yes, there IS a reason why they made the SWI-X
Old May 19, 2005 | 02:29 PM
ScrapMaker's Avatar
yeah clearly doing it without that device is next to impossible...
but you could probably buy a microcontroller that does the same thing for much cheaper... if you knew what you were doing...
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
